I am having problems outputting the raw NMEA strings coming from the Parallax GPS while using a software serial pin.
This code works great when using pin 0 and 1:
#include <string.h>
#include <ctype.h>
int rxPin = 0; // RX PIN
int txPin = 1; // TX TX
int byteGPS=-1;
char linea[300] = "";
char comandoGPR[7] = "$GPRMC";
int cont=0;
int bien=0;
int conta=0;
int indices[13];
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
Serial.begin(4800);
for (int i=0;i<300;i++){ // Initialize a buffer for received data
linea[i]=' ';
byteGPS=Serial.read(); // Read a byte of the serial port
if (byteGPS == -1) { // See if the port is empty yet
delay(100);
linea[conta]=byteGPS; // If there is serial port data, it is put in the buffer
conta++;
Serial.print(byteGPS, BYTE);
if (byteGPS==13){ // If the received byte is = to 13, end of transmission
cont=0;
bien=0;
for (int i=1;i<7;i++){ // Verifies if the received command starts with $GPR
if (linea[i]==comandoGPR[i-1]){
bien++;
conta=0; // Reset the buffer
linea[i]=' ';
and the serial monitor displays this:
And using softwareserial and pins 8 and 9:
#include <string.h>
#include <ctype.h>
#include <SoftwareSerial.h>
#define rxPin 8
#define txPin 9
SoftwareSerial mySerial = SoftwareSerial(rxPin, txPin);
int byteGPS=-1;
int cont=0;
int bien=0;
int conta=0;
int indices[13];
Serial.begin(19200);
mySerial.begin(4800);
linea[i]=' ';
byteGPS=mySerial.read(); // Read a byte of the serial port
delay(100);
conta++;
digitalWrite(ledPin, LOW);
cont=0;
bien=0;
bien++;
linea[i]=' ';
And the serial monitor prints this:
which seems to print the right data but it does not print the headers for each string and it is continuously printing horizontally.
Any suggestions will help! Thanks.
