Hello, I'm currently programming a code that will send GPS data to the server using MQTT. The device that I use for program is LilyGo T-Call SIM800 (BLYNK V1.4). The program all went okay until I update my Arduino IDE to the latest version, and the error "fatal error: SoftwareSerial.h: No such file or directory" appear. Is there any suggestion for me so I can make my code work again in the latest version of Arduino IDE?
(Note that, it is such a hassle to use another UART because I have to disconnect it before uploading the code to the board)
the code :
// Select your modem:
#define TINY_GSM_MODEM_SIM800 // Modem is SIM800L
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define SerialMon Serial
// Set serial for AT commands
#define SerialAT Serial1
// Define the serial console for debug prints, if needed
#define TINY_GSM_DEBUG SerialMon
// set GSM PIN, if any
#define GSM_PIN ""
// Your GPRS credentials, if any
const char apn[] = "my3g"; // APN
const char gprsUser[] = "";
const char gprsPass[] = "";
// SIM card PIN (leave empty, if not defined)
const char simPIN[] = "";
// MQTT details
const char* broker = "test.mosquitto.org"; // Public IP address or domain name
const char* mqttUsername = ""; // MQTT username
const char* mqttPassword = ""; // MQTT password
const char* topicGPS = "things/product/2g/94E686DFA95C/osd";
//#define DUMP_AT_COMMANDS
#include <Wire.h>
#include <TinyGsmClient.h>
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
int RXPin = 35;
int TXPin = 34;
int GPSBaud = 9600;
TinyGPSPlus gps;
SoftwareSerial gpsSerial(RXPin, TXPin);
#ifdef DUMP_AT_COMMANDS
#include <StreamDebugger.h>
StreamDebugger debugger(SerialAT, SerialMon);
TinyGsm modem(debugger);
#else
TinyGsm modem(SerialAT);
#endif
#include <PubSubClient.h>
TinyGsmClient client(modem);
PubSubClient mqtt(client);
// TTGO T-Call pins
#define MODEM_RST 5
#define MODEM_PWKEY 4
#define MODEM_POWER_ON 23
#define MODEM_TX 27
#define MODEM_RX 26
#define I2C_SDA 21
#define I2C_SCL 22
uint32_t lastReconnectAttempt = 0;
// I2C for SIM800 (to keep it running when powered from battery)
// TwoWire I2CPower = TwoWire(0);
// #define IP5306_ADDR 0x75
// #define IP5306_REG_SYS_CTL0 0x00
long lastMsg = 0;
// bool setPowerBoostKeepOn(int en){
// I2CPower.beginTransmission(IP5306_ADDR);
// I2CPower.write(IP5306_REG_SYS_CTL0);
// if (en) {
// I2CPower.write(0x37); // Set bit1: 1 enable 0 disable boost keep on
// } else {
// I2CPower.write(0x35); // 0x37 is default reg value
// return I2CPower.endTransmission() == 0;
void mqttCallback(char* topic, byte* message, unsigned int len) {
Serial.print("Message arrived on topic: ");
Serial.print(topic);
Serial.print(". Message: ");
String messageTemp;
for (int i = 0; i < len; i++) {
Serial.print((char)message[i]);
messageTemp += (char)message[i];
// Feel free to add more if statements to control more GPIOs with MQTT
// If a message is received on the topic esp/output1, you check if the message is either "true" or "false".
// Changes the output state according to the message
boolean mqttConnect() {
SerialMon.print("Connecting to ");
SerialMon.print(broker);
// Connect to MQTT Broker without username and password
boolean status = mqtt.connect(broker);
// Or, if you want to authenticate MQTT:
//boolean status = mqtt.connect("GsmClientN", mqttUsername, mqttPassword);
if (status == false) {
SerialMon.println(" fail");
ESP.restart();
return false;
SerialMon.println(" success");
return mqtt.connected();
// Set console baud rate
SerialMon.begin(9600);
gpsSerial.begin(GPSBaud);
delay(10);
// // Start I2C communication
// I2CPower.begin(I2C_SDA, I2C_SCL, 400000);
// // Keep power when running from battery
// bool isOk = setPowerBoostKeepOn(1);
// SerialMon.println(String("IP5306 KeepOn ") + (isOk ? "OK" : "FAIL"));
// Set modem reset, enable, power pins
pinMode(MODEM_PWKEY, OUTPUT);
pinMode(MODEM_RST, OUTPUT);
pinMode(MODEM_POWER_ON, OUTPUT);
digitalWrite(MODEM_PWKEY, LOW);
digitalWrite(MODEM_RST, HIGH);
digitalWrite(MODEM_POWER_ON, HIGH);
SerialMon.println("Wait...");
// Set GSM module baud rate and UART pins
SerialAT.begin(115200, SERIAL_8N1, MODEM_RX, MODEM_TX);
delay(6000);
// Restart takes quite some time
// To skip it, call init() instead of restart()
SerialMon.println("Initializing modem...");
modem.restart();
// modem.init();
String modemInfo = modem.getModemInfo();
SerialMon.print("Modem Info: ");
SerialMon.println(modemInfo);
// Unlock your SIM card with a PIN if needed
if ( GSM_PIN && modem.getSimStatus() != 3 ) {
modem.simUnlock(GSM_PIN);
SerialMon.print("Connecting to APN: ");
SerialMon.print(apn);
if (!modem.gprsConnect(apn, gprsUser, gprsPass)) {
ESP.restart();
else {
SerialMon.println(" OK");
if (modem.isGprsConnected()) {
SerialMon.println("GPRS connected");
// MQTT Broker setup
mqtt.setServer(broker, 1883);
mqtt.setCallback(mqttCallback);
if (!mqtt.connected()) {
SerialMon.println("=== MQTT NOT CONNECTED ===");
// Reconnect every 10 seconds
uint32_t t = millis();
if (t - lastReconnectAttempt > 10000L) {
lastReconnectAttempt = t;
if (mqttConnect()) {
delay(100);
return;
long now = millis();
while (gpsSerial.available() > 0)
if (gps.encode(gpsSerial.read()))
if (gps.location.isValid())
String json = "{";
json += "\"satellite\": " + String(gps.satellites.value());
json += ", \"latitude\": " + String(gps.location.lat(), 6);
json += ", \"longitude\": " + String(gps.location.lng(), 6);
json += ", \"altitude\": " + String(gps.altitude.meters());
json += "}";
// Publish JSON string to MQTT broker
char payload[json.length() + 1];
json.toCharArray(payload, sizeof(payload));
mqtt.publish(topicGPS, payload);
Serial.println(payload);
Serial.println("Location: Not Available");
// If 5000 milliseconds pass and there are no characters coming in
// over the software serial port, show a "No GPS detected" error
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println("No GPS detected");
while(true);
mqtt.loop();
If any other questions, feel free to ask. Thanks!
