SoftwareSerial Library Issue
Hey!
So I am trying to find a library called SoftwareSerial, but I am not able to find it online or even on the Library Manager for Arduino IDE. I was planning on looking at past forums, but I noticed some have links that say "404 not found". Can someone send the link?
Thanks,
ShivPat
Here
https://docs.arduino.cc/learn/built-in-libraries/software-serial/
Thank you so much. I really appreciate your help :)))
Wait there is one thing. Let me explain why I want this library.
So I am writing some code where that will input data from this sensor known as the "WT901". However, I am stumbling across a fatal error because either I don't have the library or I don't have the correct header files downloaded from the internet. If someone can glimpse and assist me, that would be awesome :))
#include <SoftwareSerial.h>
// Create a software serial port
SoftwareSerial mySerial(10, 11); // RX, TX
// Buffer to store incoming data
char dataBuffer[256];
int bufferIndex = 0;
  Serial.begin(115200); // Initialize Serial Monitor
  mySerial.begin(115200); // Initialize software serial
  Serial.println("WT901 Sensor Data:");
  // Read incoming bytes from WT901
  while (mySerial.available() > 0) {
    char incomingByte = mySerial.read();
    dataBuffer[bufferIndex++] = incomingByte;
    // Check for end of data packet (assuming '\n' signifies end)
    if (incomingByte == '\n') {
      dataBuffer[bufferIndex] = '\0';
      parseData(dataBuffer);
      bufferIndex = 0;
void parseData(char* data) {
  float accX, accY, accZ;
  float gyroX, gyroY, gyroZ;
  float magX, magY, magZ;
  // Parse the data (adjust according to your data format)
  sscanf(data, "ACC:%f,%f,%f;GYRO:%f,%f,%f;MAG:%f,%f,%f",
         &accX, &accY, &accZ,
         &gyroX, &gyroY, &gyroZ,
         &magX, &magY, &magZ);
  // Print parsed data
  Serial.print("Accelerometer: X=");
  Serial.print(accX);
  Serial.print(" Y=");
  Serial.print(accY);
  Serial.print(" Z=");
  Serial.println(accZ);
  Serial.print("Gyroscope: X=");
  Serial.print(gyroX);
  Serial.print(gyroY);
  Serial.println(gyroZ);
  Serial.print("Magnometer: X=");
  Serial.print(magX);
  Serial.print(magY);
  Serial.println(magZ);
What Arduino are you using?
Arduino Due
You don't need software serial. The Due has 4 hardware serial ports.
You don't need SoftwareSerial library on Arduino Due, because the board has a multiple hardware Serails
Ah ok. Thank you @b707 and @SurferTim :)))
