Hello, i have 3d printed and built the circuit below using the required components and schematics from https://www.instructables.com/id/Arduino-Solar-Tracker/
and i noticed that the picture diagram's pinout is different from the code, so i followed the codes pinout and made everything else the same, Except the potentiometers used for speed and tolerance, i used 20k and the diagram suggest 10k, but specifically mentions that the value of the pot doesn't matter and all i had was 20k.
When i power the circuit it doesn't work as intended and will move a little and then bug out and not work correctly. Is there anything wrong with the code or picture diagram?
#include <Servo.h> // include Servo library
Servo horizontal; // horizontal servo
int servoh = 90; // stand horizontal servo
Servo vertical; // vertical servo
int servov = 90; // stand vertical servo
// LDR pin connections
// name = analogpin;
int ldrlt = 0; //LDR top left
int ldrrt = 1; //LDR top rigt
int ldrld = 2; //LDR down left
int ldrrd = 3; //ldr down rigt
// servo connections
// name.attacht(pin);
horizontal.attach(9);
vertical.attach(10);
int lt = analogRead(ldrlt); // top left
int rt = analogRead(ldrrt); // top right
int ld = analogRead(ldrld); // down left
int rd = analogRead(ldrrd); // down rigt
int dtime = analogRead(4)/20; // read potentiometers
int tol = analogRead(5)/4;
int avt = (lt + rt) / 2; // average value top
int avd = (ld + rd) / 2; // average value down
int avl = (lt + ld) / 2; // average value left
int avr = (rt + rd) / 2; // average value right
int dvert = avt - avd; // check the diffirence of up and down
int dhoriz = avl - avr;// check the diffirence og left and rigt
if (-1*tol > dvert || dvert > tol) // check if the diffirence is in the tolerance else change vertical angle
if (avt > avd)
servov = ++servov;
if (servov > 180)
servov = 180;
else if (avt < avd)
servov= --servov;
if (servov < 0)
servov = 0;
vertical.write(servov);
