Yes, I think the first 12v pin belongs to the first relay and the second one to the second relay but in both the ground remains the same as well as input. So as if I want to drive the first relay I'll have to use the first 12v pin.
But there are only 4 pins... 2 marked 12v and 2 marked Gnd. I agree there should be 2x 5V input pins, but I don't see them on the pic in the link.
Looking at the pic of the underside of the board, it looks to me as if one of the inputs takes 12V to both relays, and the other one on the other end of the inputs takes the input signal to both transistors.
So it might be that both relays get switched together?
Looking closely I see that the first pin is 12v, the second one is the ground and the rest two pins work as the input pins to switch the relays the 3rd pin therefore switches the 1st relay and the 4th pin the 2nd relay.
Yes, clearly. But I am having trouble with powering the module. I don't think my Arduino can supply 12v power to the module so is there any other work around for that?
ojhaarjun:
I have a 7.5v adapter I tried it with my Arduino and used the Vin pin and the relay seems to be working now.
That's possible as a 12vdc relay may operate somewhat below and above it's rated coil voltage, however you are giving up reliability by not driving the relay coils at their rated nominal voltage.
