So, the interrupts seem to work insofar as “interrupting” when an event happens. My only problem is that I the interrupts will occur 2-3 times and everything essentially stops (Serial out, everything).
I was programming the board to output serially a calculated distance based on the output of the HC-SR04 distance IC. The distances are calculated accurately but, like I said earlier, everything seems to freeze. Below is both the code and an image of the serial monitor. Whichever LED is HIGH when the freeze happens is how it remains.
I thought that maybe an interrupt was occurring during an earlier interrupt call. So, I thought that by calling noInterrupt() in the functions that should not be interrupted(otherwise there would be essentially a recursive phenomena occurring) would help; it did not.
#define TRIGPIN 4
#define ECHOPIN 3
#define RED 2
#define GREEN 13
#define INTNUM 1 //interrupt pin 1 is digital pin 3 on the duemilanove
#define PULSE 10 //microseconds
#define CYCLETIME 50 //milliseconds
void ledWrite(int), trigPulse(), getTime();
int millisNow, millisPrev = 0;
int microsPrev;
boolean isHigh = false;
Serial.begin (9600);
pinMode(TRIGPIN, OUTPUT);
pinMode(ECHOPIN, INPUT);
pinMode(RED, OUTPUT);
pinMode(GREEN, OUTPUT);
attachInterrupt(INTNUM, getTime, CHANGE);
interrupts();
trigPulse();
// some other code while waiting on HC-SR04 to interrupt us when echo goes HIGH
void trigPulse(){
if( (millisNow = millis()) - millisPrev >= CYCLETIME){ //sufficient cycle time
digitalWrite(TRIGPIN, HIGH);
delayMicroseconds(PULSE);
digitalWrite(TRIGPIN, LOW);
millisPrev = millisNow; //reset clock
return;
void ledWrite(int dTime){
int distance = dTime/58.2;
if (distance < 15) {
digitalWrite(RED,HIGH);
digitalWrite(GREEN,LOW);
else {
digitalWrite(RED,LOW);
digitalWrite(GREEN,HIGH);
if (distance >= 200 || distance <= 0){
Serial.println("Out of range");
else {
Serial.print(distance);
Serial.println(" cm");
void getTime(){
int timeNow = micros();
Serial.println("Interrupted");
if(isHigh == false){
microsPrev = timeNow; //get time now, pin LOW->HIGH
isHigh = true;
Serial.println("Returning ..");
return;
else { //pin HIGH->lOW
ledWrite(timeNow - microsPrev);
isHigh = false;
microsPrev = micros();
return;
return;
