Hello,
I am having a problem with my relay switches, I have a 4 relay switch 5v for arduino and I am trying to make it so that when I push button 1 relay goes on, then I press again and relay goes off.
This works with the code although the problem is that it works only for relay 1 and only for 1 relay, if say I change the code and make multiple variable it will not work so here is the code for 1.
FIY I am using a UNO R3 ATmega 328
Keep in mind that this first code does work for only 1 relay, and it does work when I press it turn it on and then press again turns off
const int rl1 = 7;
const int rl2 = 12;
const int rl3 = 2;
const int rl4 = 8;
const int button1 = 11;
const int button2 = 10;
const int button3 = 3;
const int button4 = 4;
int rl1State = LOW;
int rl2State = LOW;
int rl3State = LOW;
int rl4State = LOW;
int buttonState = LOW;
int lastButtonState = HIGH;
int reading;
long lastDebounceTime=0;
long debounceDelay = 50;
pinMode(rl1, OUTPUT);
pinMode(rl2, OUTPUT);
pinMode(rl3, OUTPUT);
pinMode(button1, INPUT);
pinMode(button2, INPUT);
pinMode(button3, INPUT);
pinMode(button4, INPUT);
reading = digitalRead(button1);
if(reading != lastButtonState){
lastDebounceTime = millis();
lastButtonState = reading;
if((millis() - lastDebounceTime) > debounceDelay){
if(buttonState != lastButtonState){
buttonState = lastButtonState;
if(buttonState == HIGH){
rl1State = !rl1State;
digitalWrite(rl1, rl1State);
I tried this for multiple ones:
const int rl1 = 7;
const int rl2 = 12;
const int rl3 = 2;
const int rl4 = 8;
int rl1State = LOW;
int rl2State = LOW;
int rl3State = LOW;
int rl4State = LOW;
//States
int buttonState1 = LOW;
int lastButtonState1 = HIGH;
int buttonState2 = LOW;
int lastButtonState2 = HIGH;
int buttonState3 = LOW;
int lastButtonState3 = HIGH;
int buttonState4 = LOW;
int lastButtonState4 = HIGH;
//Read State
int reading1;
int reading2;
int reading3;
int reading4;
long lastDebounceTime1=0;
long debounceDelay1 = 50;
long lastDebounceTime2=0;
long debounceDelay2 = 50;
long lastDebounceTime3=0;
long debounceDelay3= 50;
long lastDebounceTime4=0;
long debounceDelay4 = 50;
reading1 = digitalRead(button1);
reading2 = digitalRead(button2);
reading3 = digitalRead(button3);
reading4 = digitalRead(button4);
if(reading1 != lastButtonState1){
lastDebounceTime1 = millis();
lastButtonState1 = reading1;
//Relay 1
if((millis() - lastDebounceTime1) > debounceDelay1){
if(buttonState1 != lastButtonState1){
buttonState1 = lastButtonState1;
if(buttonState1 == HIGH){
//Relay2
if(reading2 != lastButtonState2){
lastDebounceTime2 = millis();
lastButtonState2 = reading2;
if((millis() - lastDebounceTime2) > debounceDelay2){
if(buttonState2 != lastButtonState2){
buttonState2 = lastButtonState2;
if(buttonState2 == HIGH){
rl2State = !rl2State;
digitalWrite(rl2, rl2State);
I also tried to remake all the variables for each button and relay but still does not work
As well one of my relays does not work when put to any pin (when all the pins are connected) but it works only when one of the pins are disconnected, its really weird, I tested the relay it's fine I changed the arduino but same.
Thank you!
Yes I did post this in another thread, but I think it's the wrong one and don't know how to erase it.
