[solved]Bluetooth Problems Serial
I am trying to connect Bluetooth to my Arduino, I connected the hc-05 and downloaded app on my phone. The problem I am having is when I don't use the Serial.begin(9600) I can see the characters in my serial monitor when i use the app on my phone. But when I use Serial.begin(9600) I don't see the characters in my serial monitor. In both, the code still doesn't do what he meant to.
The code:
char data = 0;
//Serial.begin(9600);
pinMode(13, OUTPUT);
if(Serial.available() > 0)
data = Serial.read();
Serial.print(data);
Serial.print("\n");
if(data == '1')
digitalWrite(13, HIGH);
else if(data == '0')
digitalWrite(13, LOW);
explain how you wired things up
we have no clue about which app you are talking about... provide lots of information to help us help you...
5v-5v
GND-gnd
tx-Tx(digtal pin 1)
rx-rz(digtal pin 0)
im using this app-https://play.google.com/store/apps/details?id=de.kai_morich.serial_bluetooth_terminal&hl=en&gl=US
So your BT module is on the Serial port.
In a nutshell, You can either use BT or the Serial monitor, but not both at the same time.
You could use Software Serial to install the HC-05 on pin 2 and 3 for example and then Serial would remain available for debugging and uploading the code.
There are lots of examples on line for this
I tried this code and couple others and its still doesnt woek i dont get any input:
#include <SoftwareSerial.h>
SoftwareSerial MyBlue(2, 3); // RX | TX
int flag = 0;
int LED = 13;
 MyBlue.begin(9600);
 pinMode(LED, OUTPUT);
 Serial.println("Ready to connect\nDefualt password is 1234 or 000");
 if (MyBlue.available())
   flag = MyBlue.read();
   Serial.println(flag);
 if (flag == 1)
   digitalWrite(LED, HIGH);
 else if (flag == 0)
You are probably missing {} in your first if
Its not spamming 0 anymore but it still doesnt get any input.
Post the new code
Are you sure you paired the unit?
Are you sure if the baud rate ?
Did you wire Rx and Tx to the right pins ?
int flag = 0;
int LED = 13;
 MyBlue.begin(9600);
 if (MyBlue.available()){
 if (flag == 1)
 else if (flag == 0)
I am on the right baud rate 9600
I am paired with my phone
rx is connected to digtal pin 2
tx is connected to digtal pin 3
So I switched between my rx and tx and now when i send i get 3 sets of numbers
if i send a i get
97
13
10
if i send 1 i get:
49
13
10
I get the ascii of each thing but what are the 13 and 10 and how do i make it not as ascii
So final update I hope: I got it working i switched the rx and the tx so that rx is pin 3 and tx pin 2. and added in the code where it will make the ascii back to char.Thank you for the help
int flag = 0;
int LED = 13;
char character;
 MyBlue.begin(9600);
   character = char(flag);
   Serial.println(character);
 if (character == '1')
 else if (character == '0')
   digitalWrite(LED, LOW);
CarriageReturn and LineFeed; your Bluetooth app more than likely sends them (similar to what Serial.println will do).
That’s wrong - change it
Oops - sorry missed the following discussion
Seems you are all set you get the ascii code and a trailing CR and LF
