I am in the process of trying to create a three heating zone controller. I have the temperature control section working fine. The RTC and dispaly are also working fine in that the correct time and date are displaying properly. The section of code at Line 127 is meant to initiate the temperature control during a spoecific time period fom Monday to Saturday, with a different time schedule for Sundays. At present the timed section is jsut being bypassed as the temperature congtrol works fine for all three zones, irrespective of the time settings at Line 51-58. I am not sure what to change in my timeswitch coide, Any suggestions, please?
type or paste code here
// Created : 25/01/2024
// Description : Display the current date, time and temperature on the 20x4 LCD screen and create a thermostatic heating control of three zones
// Inspired from this code : File => Examples => RTClib => ds3231 along with parts from several other files/sketches
#include <Wire.h>
#include "RTClib.h"
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS_1 3
#define ONE_WIRE_BUS_2 4
#define ONE_WIRE_BUS_3 5
OneWire oneWire_range(ONE_WIRE_BUS_1);
OneWire oneWire_club(ONE_WIRE_BUS_2);
OneWire oneWire_airgun(ONE_WIRE_BUS_3);
const byte range_relay = 9; // Relay outputs
const byte club_relay = 10;
const byte airgun_relay = 11;
const byte boiler_relay = 12;
float range_temperature;
float club_temperature;
float airgun_temperature;
const float temperature_setpoint_range = 16.0; // C
const float temperature_setpoint_club = 19.0; // C
const float temperature_setpoint_airgun = 18.0; // C
const float frost_setpoint = 12; // C
const float deadzone = 0.75; // C
DallasTemperature sensor_range(&oneWire_range);
DallasTemperature sensor_club(&oneWire_club);
DallasTemperature sensor_airgun(&oneWire_airgun);
// UNCHANGABLE PARAMATERS
#define Sunday 0
#define Monday 1
#define Tuesday 2
#define Wednesday 3
#define Thursday 4
#define Friday 5
#define Saturday 6
byte Weekday[] = { 1, 2, 3, 4, 5, 6 };
byte Weekend[] = { 0 };
const int OnHour_Normal = 16; // Timeswitch settings
const int OnMin_Normal = 00;
const int OffHour_Normal = 23;
const int OffMin_Normal = 30;
const int OnHour_Sunday = 12;
const int OnMin_Sunday = 00;
const int OffHour_Sunday = 18;
const int OffMin_Sunday = 00;
LiquidCrystal_I2C lcd(0X27, 20, 4);
RTC_DS3231 rtc;
char daysOfTheWeek[7][12] = { "Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat" };
byte char_temp[8] = { B00100, B01010, B01010, B01110, B01110, B11111, B11111, B01110 }; // for thermometer icon
pinMode(range_relay, OUTPUT);
pinMode(club_relay, OUTPUT);
pinMode(airgun_relay, OUTPUT);
pinMode(boiler_relay, OUTPUT);
rtc.begin();
lcd.init();
lcd.backlight();
lcd.createChar(0, char_temp);
lcd.setCursor(4, 0);
lcd.print("Take it easy!");
lcd.setCursor(4, 1);
lcd.print("Working on it");
lcd.setCursor(2, 2);
lcd.print("G0RJM Three Zone");
lcd.setCursor(1, 3);
lcd.print("Temperature Control");
delay(3000);
lcd.clear();
if (rtc.lostPower()) {
// When the time needs to be set up on a new device, or after a power loss, uncomment the
// following line. This sets the RTC to the date & time this sketch was compiled
// rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
Serial.println("G0RJM Three zone Temperature Control");
sensor_range.begin();
sensor_club.begin();
sensor_airgun.begin();
//------------------------------Temperature control-----------------------------//
DateTime now = rtc.now();
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(" (");
Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
Serial.print(") ");
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
if ((now.hour() >= OnHour_Normal) && (now.minute() >= OnMin_Normal) && (now.second() >= 00) && (now.dayOfTheWeek() == Weekday)) {
// || (now.hour() >= OnHour_Sunday) && (now.minute() >= OnMin_Sunday) && (now.second() >= 00) && (now.dayOfTheWeek() == Weekend)) {
digitalWrite(boiler_relay, HIGH);
if (sensor_range.getTempCByIndex(0) < (temperature_setpoint_range - deadzone)) {
digitalWrite(range_relay, HIGH);
lcd.setCursor(15, 1);
lcd.print("ON T");
if (sensor_range.getTempCByIndex(0) > (temperature_setpoint_range + deadzone))
digitalWrite(range_relay, LOW);
lcd.print(" OFF");
if (sensor_club.getTempCByIndex(0) < (temperature_setpoint_club - deadzone)) {
digitalWrite(club_relay, HIGH);
lcd.setCursor(15, 2);
lcd.print("ON T");
if (sensor_club.getTempCByIndex(0) > (temperature_setpoint_club + deadzone))
digitalWrite(club_relay, LOW);
lcd.print(" OFF");
if (sensor_airgun.getTempCByIndex(0) < (temperature_setpoint_airgun - deadzone)) {
digitalWrite(airgun_relay, HIGH);
lcd.setCursor(15, 3);
lcd.print("ON T");
if (sensor_airgun.getTempCByIndex(0) > (temperature_setpoint_airgun + deadzone))
digitalWrite(airgun_relay, LOW);
lcd.print(" OFF");
if ((now.hour() >= OffHour_Normal) && (now.minute() >= OffMin_Normal) && (now.second() >= 00) && (now.dayOfTheWeek() == Weekday)
|| (now.hour() >= OffHour_Sunday) && (now.minute() >= OffMin_Sunday) && (now.second() >= 00) && (now.dayOfTheWeek() == Weekend)) {
//lcd.setCursor(column,row);
//------------------------------Date display-----------------------------//
lcd.setCursor(0, 0);
lcd.print(daysOfTheWeek[now.dayOfTheWeek()]);
lcd.setCursor(3, 0);
// lcd.print("Date:");
lcd.print(":");
if (now.day() <= 9) {
lcd.print("0");
lcd.setCursor(5, 0);
lcd.print(now.day(), DEC);
lcd.setCursor(6, 0);
lcd.print(":");
lcd.setCursor(7, 0);
if (now.month() <= 9) {
lcd.print("0");
lcd.setCursor(8, 0);
lcd.print(now.month(), DEC);
lcd.setCursor(9, 0);
lcd.print(":");
lcd.setCursor(10, 0);
lcd.print(now.year(), DEC);
//------------------------------Time display-----------------------------//
// lcd.setCursor(0, 1);
// lcd.print("Time:");
lcd.setCursor(15, 0);
if (now.hour() <= 9) {
lcd.print("0");
lcd.setCursor(16, 0);
lcd.print(now.hour(), DEC);
lcd.setCursor(17, 0);
lcd.print(":");
lcd.setCursor(18, 0);
if (now.minute() <= 9) {
lcd.print("0");
lcd.setCursor(19, 0);
lcd.print(now.minute(), DEC);
lcd.print(":");
// if (now.second() <=9 )
// lcd.print("0");
// lcd.setCursor(13,1);
// lcd.print(now.second(),DEC);
// else {lcd.print(now.second(),DEC);}
//------------------------------Temperature display - -----------------------------//
Serial.print("Requesting temperatures...");
sensor_range.requestTemperatures();
sensor_club.requestTemperatures();
sensor_airgun.requestTemperatures();
Serial.println(" done");
Serial.print("Range: ");
Serial.println(sensor_range.getTempCByIndex(0));
Serial.print("Club: ");
Serial.println(sensor_club.getTempCByIndex(0));
Serial.print("Airgun: ");
Serial.println(sensor_airgun.getTempCByIndex(0));
lcd.setCursor(0, 1); // Range
lcd.print("Range:");
lcd.setCursor(7, 1);
// lcd.print(rtc.getTemperature());
lcd.print(sensor_range.getTempCByIndex(0));
lcd.setCursor(12, 1);
lcd.write((char)223);
lcd.setCursor(13, 1);
lcd.print("C");
// lcd.setCursor(18, 1);
// lcd.print(char(0));
lcd.setCursor(0, 2); // Clubroom
lcd.print("Club:");
lcd.setCursor(7, 2);
lcd.print(sensor_club.getTempCByIndex(0));
lcd.setCursor(12, 2);
lcd.setCursor(13, 2);
lcd.print("C");
// lcd.setCursor(14, 2);
// lcd.print(" ");
lcd.setCursor(0, 3); // Airgun Range
lcd.print("Airgun:");
lcd.setCursor(7, 3);
lcd.print(sensor_airgun.getTempCByIndex(0));
lcd.setCursor(12, 3);
lcd.setCursor(13, 3);
lcd.print("C");
// lcd.setCursor(18, 3);
delay(5000);
