FoxPerr
February 14, 2018, 9:40am
#1
Recently I found a MIDI Controller Library by Mr Pieter and has doing Great Project using it. And I He makes Control Surface Library Too and I plan To build a Controller based on it
My problem is I want to add Lights (LEDs) for a specific button, such as if I press button, a LED will light up, if I pressed again the led is turn off. But no examples how to do it on the library
The code is :
#include <Control_Surface.h>
const uint8_t velocity = 0b1111111;
const uint8_t C4 = 60; on
Digital button1(2, C4, 1, velocity);
Digital button2(3, C4+1, 1, velocity);
void setup() {}
Control_Surface.refresh();
Please help me and thank you before
PieterP
February 14, 2018, 11:38am
#2
The library is not ready yet. There are no examples yet.
Pieter
system
February 14, 2018, 11:41am
#3
PieterP:
Pieter
I counted 14 of them, in the examples folder.
PieterP
February 14, 2018, 12:05pm
#4
These are just examples from the MIDI Controller library that were copied over.
FoxPerr
February 16, 2018, 12:28am
#5
PieterP:
Pieter
Oh, okay. I'll wait for that. Thank you
PieterP
February 16, 2018, 1:41am
#6
You can always check the header files to see how to use a library. You need the MIDI_LED or MIDI_Input_Note_Buffer classes .
For example:
Code: —
```#include < Control_Surface . h >
const uint8_t velocity = 0b1111111 ;
const uint8_t C4 = 60 ;
Digital button1 ( 2 , C4 , 1 , velocity ) ;
Digital button2 ( 3 , C4 + 1 , 1 , velocity ) ;
MIDI_LED led1 ( 12 , C4 , 1 ) ; // LED on pin 12, note C4, channel 1
MIDI_LED led2 ( 13 , C4 + 1 , 1 ) ;
void setup color=#000000 [/color] { }
void loop color=#000000 [/color] {
Control_Surface . refresh color=#000000 [/color];
There are definitely going to be some large API changes in the future.
Pieter
Thank You Mr Pieter. Sorry for my late respond. It Works Great. And I can add more inputs using the MCU List (your latest update).
You Are ROCK!
For the limitation of pin board, Cant wait for the Final Release with MIDI In / LED Multiplexer examples
The Latest update is Solved my problem. Instead Using Multiplexer, Its better using Shift Registers (see the example 15). Thank You Mr Pieter. You are Awesome!
VQey
March 22, 2018, 10:16pm
#9
Mr Pieter Is ROCK! He also help me on many projects. Here is a code I got from Mr Pieter if you want to use it for MIDI out with multiplexer
#include <MIDI_Controller.h> // Include the library
const pin_t muxPin = 5;
AnalogMultiplex multiplexer(muxPin, { 2, 3, 4 } );
Digital buttons[] = {
{multiplexer.pin(0), 0x10, 1},
{multiplexer.pin(1), 0x10, 2},
{multiplexer.pin(2), 0x10, 3},
{multiplexer.pin(3), 0x10, 4},
{multiplexer.pin(4), 0x10, 5},
{multiplexer.pin(5), 0x10, 6},
{multiplexer.pin(6), 0x10, 7},
{multiplexer.pin(7), 0x10, 8}
::pinMode(muxPin, INPUT_PULLUP);
MIDI_Controller.refresh();
I dont know if its work with Control Surface Library. But its Working great on MIDI_Controller Library.
