[solved] Controlling two DC motors with HX1838 IR remote, one motor not running.
Hello world,
I have two dc motors connected to a TB6612FNG motor driver with a separate 6V power supply. The driver is connected to a Arduino Nano.
I have been testing the setup with a POT, connected to the Nano, running the motors in one direction when the POT is turned CW, stopping the motors with the POT in the center position and running the motors in the other direction when the POT is turned CCW.
This is working as expected.
Next I am trying to replace the POT with the HX1838 IR remote and receiver, using three different buttons on the remote to control the motors at constant speed.
Running this code I am not able to get both motors running. The code from the remote is read, and the right function is called. but only Motor 2 is running.
Looking at the two codes I do not understand why this is not working. If someone can take a look at my codes and explain what I am doing wrong I would very much appreciate it.
Code with POT:
// Test of TB6612FNG with POT and two motors
// STBY for enabeling the H-bridge
const int STBY=12;
//  Motor 1
const int AIN1=8;
const int AIN2=9;
const int PWMA=3;
//  Motor 2
const int BIN1=10;
const int BIN2=11;
const int PWMB=5;
//  POT on analog inn 0
const int POT=0;
int val = 0;  // For storing the reading from POT
int velocity = 0; // For storing the velocity
  pinMode(STBY, OUTPUT);
  pinMode(AIN1, OUTPUT);
  pinMode(AIN2, OUTPUT);
  pinMode(PWMA, OUTPUT);
  pinMode(BIN1, OUTPUT);
  pinMode(BIN2, OUTPUT);
  pinMode(PWMB, OUTPUT);
  brake(); // Start with motors stopped
  val = analogRead(POT);
  //  Forward
  if (val > 562)
    velocity = map(val, 563, 1023, 0, 255);
    forward(velocity);
  //  Reverse
  else if (val < 462)
    velocity = map(val, 461, 0, 0, 255);
    reverse(velocity);
  //  Brake
    brake();
//  Function Forward
void forward (int rate)
  digitalWrite(STBY, LOW);
  digitalWrite(AIN1, HIGH);
  digitalWrite(AIN2, LOW);
  digitalWrite(BIN1, LOW);
  digitalWrite(BIN2, HIGH);
  digitalWrite(STBY, HIGH);
  analogWrite(PWMA, rate);
  analogWrite(PWMB, rate);
// Function Reverse
void reverse (int rate)
  digitalWrite(AIN1, LOW);
  digitalWrite(AIN2, HIGH);
  digitalWrite(BIN1, HIGH);
  digitalWrite(BIN2, LOW);
// Function Brake
void brake ()
Code with IR-remote:
// Test of TB6612FNG with two motors and IR-remote
#include <IRremote.h>
//  Constant for the speed
#define VELOCITY 200
const int STBY=12;
//  Motor 1
const int AIN1=8;
const int AIN2=9;
const int PWMA=3;
//  Motor 2
const int BIN1=10;
const int BIN2=11;
const int PWMB=5;
//  IR-reciever
const int IR=2;
IRrecv irrecv(IR);     // Create instance of 'irrecv'
decode_results results;      // Create instance of 'decode_results'
  irrecv.enableIRIn(); // Start the receiver
  if (irrecv.decode(&results)) // Have we received an IR signal?
    irrecv.resume(); // Receive the next value
    Serial.println(results.value, HEX);
  //  Forward
  if (results.value == 0xFF629D)
     forward(VELOCITY);
  //  Reverse
  if (results.value == 0xFFA857)
    reverse(VELOCITY);
  //  Brake
  if (results.value == 0xFF02FD)
    brake();
//  Function Forward
  Serial.println("-Forward-");
// Function Reverse
  Serial.println("-Reverse-");
// Function Brake
void brake ()
  Serial.println("-Brake-");
The IR library uses a timer. PWM uses a timer. The timer used by the IR library is fixed. The timer used by PWM depends on which pins are being PWM'd. Try connecting your speed pins to different PWM pins.
There is no reason to use a PWM pin to control direction.
Thank you so much PaulS,
Moved the speed pins to PWM pins 9 and 10 and everything works fine.
