[Problem solved]
hi all guys..
well I got arduino uno r3 and ehternet shield, im trying with arduino as server and I have mount a HTML page here, my problem is I can't get a code from the html to var, look this:
im trying this
I want get a data becuase I maked a login.. then Im tryied to put some like JS and php but dont work that for me
anyway I tried to get the user and psw in this case how im experiment whit this just I put the "user" and I want to put the "user"(ID to login) and give to var "ID" but I know that I'm doing that so bad.. Im here for any solution I have 1 week trying to resolve this.
sorry for my english is not my primary language. for more info just call it and I can give you.. that's all thx!
[Solution]
in html code I used function "onclick" then can write in the link the user entered. inside arduino code have an IF:
int OPC = readString.indexOf("Log="); //Read the link to 'Log='
if(readString.substring(OPC,OPC+5)=="Log=T")
{ do something } //in this case write Index.html
Have you looked at what the print() method for whatever class cliente is an instance of returns? It is most likely NOT something that can be meaningfully cast to a const char.
The cliente.read() method MIGHT be what you are needing to use.
PaulS:
okay then I need try with: String id= String(cliente.read("value1")); or String id= String(cliente.read("document.form1.user.value"));
I'm right sure? or Im doing something wrong?
anyway Im tried with: String id= String(cliente.read("value1")) and sketch throw "no matching function for call to 'EthernetClient::read(const char [7]'"
I cant undesrtand that can you guide me a little please?
The read() method doesn't take any arguments. It knows where to read from. It returns the value that it read. You need to store those characters somewhere, until you know that you have read a whole packet.
Xendor:
There are two parts to the problem.
You need to design the page so that when the user enters the name+password and requests a login, the page submits the values in an HTTP request.
Then when receiving the HTTP request you need to parse the request to recognise that it is a login request and extract the name+password values that were submitted.
You should have no trouble finding existing examples of both parts, but the code you quoted doesn't look anywhere close so I suggest that you start by looking at how other people solve the problem.
well.. unfortunately I was struggling to find examples, that's why I came here as a last option, because I have run out of ideas, also the english is not my first language then I took longer to understand something.
Is there a section here in the forum that does use your language? There are many different places in this forum that do use other languages. I do believe that Google is multilingual, If it isn't let me know and I'll do something about it promptly.
Simple server test code that captures the contents of a text box and looks in it for info, and changes an arduino pin start.
//zoomkat 12-08-12
//get submit box code
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html or use a '
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84);; //server port
String readString;
void setup(){
 pinMode(5, OUTPUT); //pin selected to control
 //start Ethernet
 Ethernet.begin(mac, ip, gateway, subnet);
 server.begin();
 //enable serial data print
 Serial.println("server text box test1"); // so I can keep track of what is loaded
void loop(){
 // Create a client connection
 if (client) {
  while (client.connected()) {
   if (client.available()) {
    char c = client.read();
    //read char by char HTTP request
    if (readString.length() < 100) {
     //store characters to string
     readString += c;
     //Serial.print(c);
    //if HTTP request has ended
    if (c == '\n') {
     Serial.println(readString); //see what was captured
     //now output HTML data header
     client.println("Content-Type: text/html");
     client.println();
     client.println("<HTML>");
     client.println("<HEAD>");
     client.println("<TITLE>Arduino GET test page</TITLE>");
     client.println("</HEAD>");
     client.println("<BODY>");
     client.println("<H1>HTML form GET example</H1>");
     client.println("<FORM ACTION='/' method=get >"); //uses IP/port of web page
     client.println("Pin 5 'on' or 'off': <INPUT TYPE=TEXT NAME='LED' VALUE='' SIZE='25' MAXLENGTH='50'>
     client.println("<INPUT TYPE=SUBMIT NAME='submit' VALUE='Change Pin 5!'>");
     client.println("</FORM>");
     client.println("
     client.println("</BODY>");
     client.println("</HTML>");
     delay(1);
     //stopping client
     client.stop();
     if(readString.indexOf("on") >0)//checks for on
      digitalWrite(5, HIGH);  // set pin 5 high
      Serial.println("Led On");
     if(readString.indexOf("off") >0)//checks for off
      digitalWrite(5, LOW);  // set pin 5 low
      Serial.println("Led Off");
     //clearing string for next read
     readString="";
