What are you using the CRC for? If for error checking then what matters is that the CRC you calculate at the beginning of whatever you are doing matches the one at the end when you want to check for errors. The actual number doesn't matter.
Hi. I understand what you are saying but unfortunately its not as simple as that.
Am trying to talk / control an HAV system which uses the above CRC check, so its important to get it right!
Now i am even more Confused!
I am expecting 0xD5. This is what the online tool i linked gjves and, more importantly, this is what the system i wanna talk to you gives as well!
Edit: You didn't select CRC -WCDMA from drop down list at tge top
// Function to reflect (mirror) a byte
uint8_t reflect_byte(uint8_t byte)
uint8_t reflected = 0;
for (int i = 0; i < 8; i++) {
// Shift the existing bits of `reflected` to the left
reflected <<= 1;
// Add the least significant bit of `byte` to `reflected`
reflected |= (byte & 1);
// Shift the original `byte` to the right to process the next bit
byte >>= 1;
return reflected;
// Define the polynomial for CRC-8-WCDMA
#define CRC8_WCDMA_POLY 0x9B
uint8_t cmd[25] = {
0x40, 0x00 ,0x10 ,0x00 ,0x00 ,0x61 ,0x01 ,0x16 ,0x00 ,0x31 ,0x00 ,0x3A ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x82 ,0x00 ,0x00 ,0x00 ,0x00 ,0x80 };
// Function to calculate CRC-8-WCDMA
uint8_t calculateCRC8_WCDMA(uint8_t* data, size_t length) {
uint8_t crc = 0x00; // Initial CRC value
for (size_t i = 0; i < length; i++) {
crc ^= reflect_byte(data[i]); // XOR byte into the current CRC
// Process each bit
for (uint8_t bit = 0; bit < 8; bit++) {
if (crc & 0x80) { // If the MSB is 1
crc = (crc << 1) ^ CRC8_WCDMA_POLY; // Shift and XOR with the polynomial
else {
crc <<= 1; // Just shift if MSB is 0
return reflect_byte(crc); // Return the final CRC value
Full disclosure : the reflect_byte() function is AI generated.
//Reverse the bits in a byte with 7 operations (no 64-bit):
b = ((b * 0x0802LU & 0x22110LU) | (b * 0x8020LU & 0x88440LU)) * 0x10101LU >> 16;
Make sure you assign or cast the result to an unsigned char to remove garbage in the higher bits. Devised by Sean Anderson, July 13, 2001. Typo spotted and correction supplied by Mike Keith, January 3, 2002.
Which would be fastest must be tested, I would have to test anyway - modern compilers seem to be very good at making code.
