Good day.
Is there any freeRTOS for Due.
Who has experience with her.
Select, in the Arduino IDE, Sketch|Inclue Library|Manage Libraries, type in "freertos" and select the proper library for your product. You may want to refer to this link FreeRTOS API categories, I know I often refer to that link.
There are two libraries with freeRTOS there. One for SAM-D, one for AVR.
Consider the overhead of running freeRTOS on a DUE. freeRTOS is not DUE native as freeRTOS on an ESP32 would be. On a DUE freeRTOS would occupy memory space whiles on a ESP32 freeRTOS is built-in.
You could do some research into which product you are using a SAM-D or an AVR.
Arduino Due is sam. Not avr and not sam-d.
FreeRTOS by Richard Berry Version 8.2.3-18 INSTALLED
Real Time Operating System implemented for AVR (Uno, Leonardo, Mega). The primary design goals are: Easy to use, Small footprint, Robust. Uses Watchdog Timer for 15ms resolution. Slow blink = stack overflow. Fast blink = heap malloc() failure.
Due is not in the list.
DrAngelOK:
Real Time Operating System implemented for AVR (Uno, Leonardo, Mega). The primary design goals are: Easy to use, Small footprint, Robust. Uses Watchdog Timer for 15ms resolution. Slow blink = stack overflow. Fast blink = heap malloc() failure.Due is not in the list.
You have your answer about the DUE and freeRTOS.
