(SOLVED) Handling of file path information on Windows / Linux
I want to analyze a file path in an Arduino program on Windows and on Linux (Raspberry Pi), for example to isolate the file name.
  • in Windows the separator is ''
  • In Linux, the separator is '/'.
    How can i identify it? My example: isolate the file name from the specification FILE
The Windows version:
  strcpy(fname,strrchr(__FILE__,'\\') + 1);
The Linux version ???
  strcpy(fname,strrchr(__FILE__,'/') + 1);
Is there a constant like "Operating system" that is usable as an if argument?
The strtok() function allows you to split a string into component parts. You can use both the / and \ as separators in the same call to strtok() if that helps
On Windows your FILE variable will start with "C:" or whatever drive it resides on. On my Mac and I expect on a Pi, it will start "/". So just check whether the first character is '/' to tell you which system it came from.
Hello - thank you both, so I will find a solution with one of your hints!
