[SOLVED] Hardware Serial receiving 0 bytes, but RX LED blinking
I am having quite a strange issue. Hardware serial through USB works without any problems, however when I connect with the D0/RX port I don't receive any data.
My test setup
I have connected a NEO6M GPS module to my hardware RX port on an Arduino nano clone (WAVGAT nano). The NEO6M GPS module is also connected to 5V Perhaps the problem is that it is a clone board. However, since the hardware serial does work through USB, I can't imagine that being the issue. (If it is, could you tell me why?) (I guess I was wrong)
here is an image of the clone board circuit if that helps
I have a Bluetooth module connected through Software Serial pins (8 and 9). The Bluetooth connection works fine without any issues.
The reason why I want to use hardware serial for the GPS module is that the reliability of software serial work
Test Code (Very straight forward)
#include "SoftwareSerial.h"
SoftwareSerial ss = SoftwareSerial(8, 9);
  ss.begin(4800);
void passThrough() {
  int16_t byte;
  while ((byte = Serial.read()) >= 0) {
    ss.write(byte);
void sendByteCount() {
  uint8_t bytes = 0;
  while (Serial.read() >= 0) {
    bytes++;
  ss.print(F("Received "));
  ss.print(bytes, 10);
  ss.println(F(" bytes"));
  // passThrough();
  // wait a bit for data to be received
  delay(100);
  sendByteCount();
Observations
  • I do receive data from the NEO6M module when using software serial.
  • I do receive data from hardware Serial when using a USB connection.
  • RX LED led is blinking when connected to RX, TX LED is blinking when connected to TX
What I have tried so far that hasn't worked
  • Tried different baud rates (2400, 4800, 9600 (the default))
  • Swapped RX, and TX wires to make sure that wasn't the issue.
I am quite good with software however, the hardware is still a challenge sometimes. So I genuinely hope someone can give me advice on what the problem could be because I have run out of ideas.
Solution:
The USB Controller and the NEO6M GPS module are fighting over the Serial connection, which caused conflict. Disabling the USB Controller's UART (Ripping off the RX and TX pins) solved this problem!
You wrote: "since the hardware serial does work through USB". Can you tell us why you think this is true?
Paul
Yes, thank you for your reply.
Perhaps I am misunderstanding something, but I would think that the RX TX pins from the USB controller are connected to D0 and D1 pins. I don't know how else they could connect that hardware serial.
I suspect (although I don't 100% know, so take with a pinch of salt!) that you're going to struggle to use the hardware serial port to talk to the GPS module in the way that you want. I had a quick look at the Nano schematics and although the ATMega328P's RX/TX pins are connected to the header D0/D1 pins as you say, they're also directly connected through to the USB/Serial chip.
Possibly there is a way to disable the USB/Serial chip or something, but otherwise I think you're out of luck.
On a more positive note: it's not impossible to interface with a NEO6M using software serial from an ATMega328P. I have had good results using libraries from here: SlashDevin · GitHub -- specifically the NeoGPS and NeoSWSerial libraries.
A very minimal example (coded for Uno, you might need to transpose the pin numbers for a Nano, but the point is they're just common-or-garden digital I/O pins):
#include "NeoSWSerial.h"
#include "NMEAGPS.h"
#define GPS_BAUD 9600
#define GPS_SERIAL_RX_PIN 3
#define GPS_SERIAL_TX_PIN 2
static NeoSWSerial gpsSerial(GPS_SERIAL_RX_PIN, GPS_SERIAL_TX_PIN);
static NMEAGPS gps;
    gpsSerial.begin(GPS_BAUD);
    while(gps.available(gpsSerial)) {
        gps_fix = gps.read();
        // TODO: print out GPS fix information, see the NEOGPS examples for guidance
FWIW, I've used this in a project with a 5Hz GPS update rate (although restricted NMEA sentences) and the software serial implementation apparently keeps up, in that I get valid fix information back to my Arduino loop() function on a ~200ms interval.
While I'm here -- a couple of observations.
#1. I don't know what NEO6M module you're using, but the one I have (GY-NEO6MV2) uses 3.3v logic for it's serial interface. So I needed to add some circuitry to interface it with the ATMega328P's 5v levels. A simple howto is here: NEO6MV2 GPS Module with Arduino • Computer Science and Machine Learning
#2. You appear to be mixing up data types when working with the serial API.
  uint16_t byte;
    ss.write(byte);
In this function you are taking the the output of Serial.read() (an int, which for ATMega boards is a signed 16 bit integer), and assigning it to an unsigned variable uint16_t. Check the language standards for exactly what happens, but it probably isn't what you expect/want, and it certainly isn't ever going to be < 0, since unsigned variables can't represent negative numbers. Hence the while loop there is going to be infinite, since the byte variable can only ever be >=0.
For the goal of "read from the serial port while data is available" you can try the Serial.available() method:
while (Serial.available()) {
   int c = Serial.read();
   // TODO: do something with c
Hey tomparkin, thank you for your reply.
A single software serial does indeed work without issues, but through my testing, I found that I get a lot of corrupt data when using two software serials. Especially when the Arduino is being busy doing a lot of other things as well.
My code is using the UBX protocol currently to do less string parsing, but perhaps their software serial may be a good alternative to do some testing on. It is still strange that hardware Serial is not working though. Would still like to find a solution for that, but I have a backup plan now at least.
@observation #1: I have the module powered with 5V. I hadn't mentioned that, but it's a good observation.
@observation #2 good catch. It should be an int16_t instead. A mistake I'd probably have caught if I had any data coming though :stuck_out_tongue:
I'll edit my original post, to fix my code and mention the 5V thing.
Ah, OK -- that wasn't clear to me previously. It may be worth posting your code using the two software serial interfaces.
I note also that the NeoGPS library code has a good comment about serial port choices in src/GPSport.h (possibly this is driving your attempt to use the hardware serial interface?) which is worth a read if you've not done so already.
Uncertain :-/
The reason I'm sceptical TBH is that TTL serial is driven by the sender, and is high when idle (ref: e.g microcontroller - How does TTL serial work? - Electrical Engineering Stack Exchange). A start/stop "low bit" is used to indicate the beginning and end of a data byte.
So as you can see, if the USB/serial chip AND the NEO6M both think they're "the sender" for the ATMega's RX pin, the USB/Serial will normally be driving the line to Vcc. When the NEO6M tries to drive it low for the serial start bit, there's going to be a fight between the USB/Serial and the NEO6M over whether the line is high or low. It's probably not going to result in happiness.
As I said before though, there may be a way to disable the USB/serial chip perhaps.
Oh I see. I have tested it with just external power through VIN thinking that it may interfere if USB is plugged in or something. But perhaps that is not enough to disable it?
I will do some googling, at least I have some direction to search in now, so it's already progress :slight_smile:
I couldn't find a way to disable the UART in the USB controller through software, so I have ripped off the RX and TX pins from the USB controller, and now it works!
Which means that this was indeed the problem. I'll mark my original as solved. So I reckon it was an issue with the CH340G USB controller on the clone board.
Thank you for your help!
mmdk95:
Crikey, that's fairly drastic :slight_smile:
Doesn't that mean you can no longer upload code to the Arduino? Or are you using ICSP to flash it?
Anyway -- so long as you got it working it's all good.
Yes very drastic, couldn't find another way. and yes, you can no longer upload through the USB. and yes I use an ICSP now haha
