This is my first project and first post on here. I have tried to create a simple program that would ping the Google DNS server and if this fails a set number of times then it is to switch a relay off, then back on. (the point being to power cycle my modem) Once I get this working the plan was to have 2 pings with the other being to a local IP address on my network and to toggle a second relay if that ping fails.
So far I have the below code but all it does is connect to the network and then turn the relay off after a few seconds. In the serial monitor I don't get any attempt for a ping at all. I'm guessing its to do with my 'while' loop being wrong but I'm far too new to this to see my error. This is going on a NodeMCU (ESP8266) programmed with the Arduino IDE.
Can someone please help me out?
this program checks to see if it can Ping the Google DNS server and if the Ping fails
'pingIP1failmax' times in a row if will turn relay 1 OFF for 10 seconds and then back ON. It will
do a simlar thing with relay 2 if it cant Ping the HassIO server IP.
#include <ESP8266WiFi.h>
#include <ESP8266Ping.h>
//#include <ESP8266Ping.impl.h>
// Update these with values suitable for your network.
const char* ssid = "SSID";
const char* password = "PASSWORD";
const IPAddress remote_ip1(8, 8, 8, 8);
const IPAddress remote_ip2(192, 168, 0, 13);
int pingIP1count = 0;
int pingIP1fails = 0;
int pingIP1failmax = 0;
int pingIP2count = 0;
int pingIP2fails = 0;
int pingIP2failmax = 0;
WiFiClient espClient;
pinMode(5, OUTPUT); // Initialize the GPIO5 pin as an output
pinMode(4, OUTPUT); // Initialize the GPIO4 pin as an output
digitalWrite(5, LOW); // Turn GPIO5 on (Note that LOW is the voltage level
// but actually the Relay is on; this is because
// it is acive low on the ESP-01)
digitalWrite(4, LOW);
setup_wifi();
void setup_wifi() {
delay(10);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
randomSeed(micros());
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
while(pingIP1fails < pingIP1failmax){
Serial.print("Pinging Google DNS Server ");
Serial.println(remote_ip1);
if(Ping.ping(remote_ip1)){
Serial.println("Success!!");
delay(600);
else {
Serial.println("Error :(");
++pingIP1fails; // = ++pingIP2fails;
digitalWrite(5, HIGH); // Turn GPIO5 off
delay(10);
pingIP2fails = 0;
OK, so I realised I had accidentally left the 'pingIP1failmax' equal to zero so it would drop out of the 'while' loop straight away. I have changed that to 3 as I had originally planned and now the program works... except that it constantly retries the Ping whereas I wanted it to delay for 5 mins before trying again. Why would the delay in the above code not be working?
EDIT: I'm an idiot. I was still thinking of a different programming language where a delay is in seconds, not milliseconds. Changed the delay time and things are looking good.
I have fixed up my code so thought I'd post it here for thread completeness if anyone else is interested later (although I haven't yet implemented the second relay, that's still to be done).
const char* ssid = "xxSSIDxx";
const char* password = "xxPASSWORDxx";
int pingIP1failmax = 3;
int pingIP2failmax = 3;
int retryTime = 300000;
int retryTimeMins = retryTime / 60000; //convert time to minutes
setup_wifi();
void setup_wifi() {
delay(10);
Serial.print(".");
Serial.println("");
delay(retryTime);
Serial.print("Success! Will try ping again in ");
Serial.print(retryTimeMins);
Serial.println(" minutes");
else {
Serial.println("PING FAILED!");
Serial.print("Incrementing pingIP1fail count to ");
++pingIP1fails; // Increment pingIP1fails counter
Serial.println(pingIP1fails);
Serial.println("Switching relay 1 OFF for 10 seconds to reboot router and resetting pingIP1fails to zero");
delay(10000); // Delay 10 seconds
pingIP1fails = 0;
