[Solved!] I can't pair my two HC05 module together
Edit: I solved the problem. For some reason Slave HC05 is resetting it's password to default after I unplug it. So I just changed Master HC05's password as the default one. After that, they worked!
Hello! I have two HC05 Bluetooth modules. I already set them as Slave and Master. I also bind them and set their passwords to be the same. But for some reason, when I wanted to test it, I noticed that the HC05's LEDs didn't blinking at the same time and the modules didn't match each other. When I enter the AT+STATE command into the Master HC05, I get the "+STATE:READY" output instead of the "+STATE:CONNECTED" output. I don't know why but for some reason my HC05 modules are not connecting to each other. When I enter the "AT+INQ" command, I can see my Slave HC05 but I cannot connect them together even though the bind address and passwords are the same. I looked for a solution on the internet but couldn't find anything that worked. What could be causing the problem? Thank you in advance for your help!
