When I click the icon to start Arduino IDE, literally nothing pops up. No window, not even an error message. The icon just shows up on the dock, bounces a few times, then nothing. Here is a video:
Here is what happens when I open it from the terminal:
Last login: Thu Oct 12 18:36:44 on console
XXXXXXXX@wireless-10-145-44-214 ~ % "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
Arduino IDE 2.2.1
Checking for frontend application configuration customizations. Module path: /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/electron-main.js, destination 'package.json': /Applications/Arduino IDE.app/Contents/Resources/app/package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.2.1" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.34.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2023-08-31T14:26:39.874Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.2.1","cliVersion":"0.34.0","buildDate":"2023-08-31T14:26:39.874Z"}
Starting backend process. PID: 877
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///Users/XXXXXXXX/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-10-12T23:46:25.583Z root INFO Backend Object.initialize: 6.9 ms [Finished 0.668 s after backend start]
2023-10-12T23:46:25.586Z root INFO Backend Object.configure: 5.8 ms [Finished 0.668 s after backend start]
2023-10-12T23:46:25.586Z root INFO Backend a.onStart: 2.1 ms [Finished 0.668 s after backend start]
2023-10-12T23:46:25.587Z root INFO Backend a.configure: 0.5 ms [Finished 0.706 s after backend start]
2023-10-12T23:46:25.588Z root INFO Backend u.onStart: 0.4 ms [Finished 0.706 s after backend start]
2023-10-12T23:46:25.590Z root INFO Backend d.configure: 0.2 ms [Finished 0.707 s after backend start]
2023-10-12T23:46:25.590Z root INFO Backend d.initialize: 38.5 ms [Finished 0.707 s after backend start]
2023-10-12T23:46:25.591Z root INFO Backend c.onStart: 0.4 ms [Finished 0.707 s after backend start]
2023-10-12T23:46:25.591Z root INFO Backend s.configure: 4.6 ms [Finished 0.712 s after backend start]
2023-10-12T23:46:25.593Z config INFO >>> Initializing CLI configuration...
2023-10-12T23:46:25.593Z root INFO Backend c.initialize: 0.7 ms [Finished 0.712 s after backend start]
2023-10-12T23:46:25.594Z root INFO Backend P.onStart: 1.1 ms [Finished 0.713 s after backend start]
2023-10-12T23:46:25.595Z config INFO Loading CLI configuration from /Users/XXXXXXX/.arduinoIDE/arduino-cli.yaml...
2023-10-12T23:46:25.595Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-10-12T23:46:25.596Z root INFO Backend s.initialize: 0.5 ms [Finished 0.714 s after backend start]
2023-10-12T23:46:25.596Z root INFO Backend w.onStart: 1.4 ms [Finished 0.715 s after backend start]
2023-10-12T23:46:25.596Z root INFO Backend r.configure: 2.5 ms [Finished 0.715 s after backend start]
2023-10-12T23:46:25.596Z discovery-log INFO start
2023-10-12T23:46:25.596Z discovery-log INFO start new deferred
2023-10-12T23:46:25.596Z root INFO Backend d.initialize: 0.5 ms [Finished 0.716 s after backend start]
2023-10-12T23:46:25.596Z root INFO Backend y.onStart: 2.4 ms [Finished 0.718 s after backend start]
2023-10-12T23:46:25.597Z root INFO Backend r.configure: 2.2 ms [Finished 0.719 s after backend start]
2023-10-12T23:46:25.597Z root INFO Backend s.onStart: 0.7 ms [Finished 0.720 s after backend start]
2023-10-12T23:46:25.597Z root INFO Backend h.configure: 0.8 ms [Finished 0.720 s after backend start]
2023-10-12T23:46:25.597Z root INFO Backend a.configure: 0.4 ms [Finished 0.721 s after backend start]
2023-10-12T23:46:25.597Z root INFO Backend s.configure: 0.1 ms [Finished 0.721 s after backend start]
2023-10-12T23:46:25.597Z root INFO Backend l.configure: 0.1 ms [Finished 0.722 s after backend start]
2023-10-12T23:46:25.599Z root ERROR Failed to start the backend application:
2023-10-12T23:46:25.599Z root ERROR Error: getaddrinfo ENOTFOUND localhost
at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:107:26)
2023-10-12T23:46:25.599Z root ERROR Uncaught Exception: Error: getaddrinfo ENOTFOUND localhost
2023-10-12T23:46:25.600Z root ERROR Error: getaddrinfo ENOTFOUND localhost
I have a MacOS Big Sur v11.17. It has an intel core, and so I got the MacOS intel version of the IDE. I have tried deleting and reinstalling. I have restarted my laptop. Nothing has worked. I don't know what is happening.
