SOLVED ! is there a way of putting preceding '0's in a print?
If i have
if (seconds<10)
  lcd.setCursor(7,0);
  lcd.setCursor(6,0);
  lcd.print(seconds);
I can get a two figure number to show up right but is there any way of just putting
lcd.print (seconds,'something') so that it gives me leading '0's?
You want 04 for example.
Print a 0 if the number is less than 10, next print the number.
Try
printf("%02d",seconds);
Lcd.print(seconds);
I think you can get rid of the seconds condition with this code as well.
Yep, use the "print2digits" approach as below:
#include <Wire.h>
#include <Time.h>
#include <DS1307RTC.h>
  while (!Serial) ; // wait for serial
  delay(200);
  Serial.println("DS1307RTC Read Test");
  Serial.println("-------------------");
  tmElements_t tm;
  if (RTC.read(tm)) {
    Serial.print("Ok, Time = ");
    print2digits(tm.Hour);
    Serial.write(':');
    print2digits(tm.Minute);
    Serial.write(':');
    print2digits(tm.Second);
    Serial.print(", Date (D/M/Y) = ");
    Serial.print(tm.Day);
    Serial.write('/');
    Serial.print(tm.Month);
    Serial.write('/');
    Serial.print(tmYearToCalendar(tm.Year));
    if (RTC.chipPresent()) {
      Serial.println("The DS1307 is stopped.  Please run the SetTime");
      Serial.println("example to initialize the time and begin running.");
      Serial.println("DS1307 read error!  Please check the circuitry.");
    delay(9000);
void print2digits(int number) {
  if (number >= 0 && number < 10) {
    Serial.write('0');
  Serial.print(number);
mistergreen,
I altered my program to include
 lcd.setCursor(6,0);
  lcd.print(seconds);
but I still get 1-9 on line 7 and then 10-59 on lines 7 and 8. What I wanted was 00-09 to show on lines 7 and 8 and then 10-59 on line 7 and 8.
jimboZA, I don't need the date and I am printing to a 1 line lcd so I will see if I can alter your program soon, thanks to both of you for the replies.
if (seconds<10)
  lcd.setCursor(6,0);
  lcd.print('0');
  lcd.setCursor(7,0);
  lcd.setCursor(6,0);
  lcd.print(seconds);
yea LarryD if you read my question that is almost what I have and in fact since I wrote it I have added the '0's but I was asking if there is any way to tell the program to print the leading '0's by saying 'give me a two figure number' similar to mistergreens %02d. I am just learning and wonder if there is a way of doing that.
Hi matelot.
Take a look at this:
sprintf(buffer, "%02d:%02d:%02d", hour, min, sec);
lcd.print(buffer); //< You will get "13:02:00"
See this for parameters (float will not work though)
http://www.cplusplus.com/reference/cstdio/printf/
thanks LarryD,
I read through your link and found an error that you may see straight away but I know little about arrays at this point so had no idea what was wrong.
I know a lot more about arrays now
the line
char [9] buffer = "";
brings up
expected unqualified-id before '[' token
when compiled but
char buffer[9] = "";
works fine and I think is a neater way than the way I was doing.
Thanks.
Congrats!
You are an expert now.
do I get a badge :confused: ......or something?
