[SOLVED]Millis() loop timer strange result
The code below should produce a number range that looks like this
50
100
250
but the code produces
50
101
152
203
254
305
Thr question is why
int count = 0;
int tmrNow = 0;
static unsigned long tmrPrev = 0;
  tmrPrev = millis();
  if (millis() - tmrPrev >= 5000UL) {
    Serial.print(millis() / 1000);
    Serial.println(count);
    count++;
    tmrPrev = millis();
Because there is no guarantee that when you do tmrPrev = millis(); millis won't have incremented a bit.
Try:
tmrPrev += 5000UL;
Only use one copy of millis per loop execution
  unsigned long timeNow = millis();
  if (timeNow - tmrPrev >= 5000UL) {
    Serial.print(timeNow / 1000);
    count++;
    tmrPrev += 5000UL;
Oh stupid myself, I forgot a Serial.print()
    Serial.print(" - ");
Onmitting the extra print the result looks like a complete number
Until you add more code.
