I have an Olimex AVR-ISP500 hooked up to a 328p on a breadboard. So that I can use it with the Arduino IDE, I added the following to the programmers.txt file:
Now, I can burn a bootloader by selecting the proper programmer (AVR ISP 500 Olimex) and board in the IDE, and I can also burn sketches with 'Upload using programmer'. The problem is, It. Is. Very. Slow.
This first manifests itself when writing the bootloader. It writes fine, however it never verifies because it times out several times during that step and eventually the IDE quits and says it can't verify. But the bootloader's burned just fine. I say this because I have an LED connected to pin 13 and it blinks like it should after you've burned a bootloader. And, I can upload a sketch (though that blows away the bootloader) and that too works. I have not tried to do any kind of serial communications between this 328p and another ...
What I can't figure out is if it's normal for it to be so slow. Burning the bootloader (prior to verifying) takes almost five minutes. Burning a sketch that just turns on then off that LED takes about a minute and a half. Is it because there's no speed declaration in the programmers.txt file? Or is it slow by design?
The 328p has a resonator on it (16MHz), power, everything works, it's just very slow and never passes the bootloader verification (which I suspect is because it times out waiting for data.)
KirAsh4:
No. That is not normal. It should take a few seconds.
No. Unless the Olimex folks did something dumb, communications between the PC and the programmer should always be at 12 Mbs. From their webpage... "connects to PC via USB 2.0 Full speed".
That is certainly a possibility. But I cannot imagine why they would do that.
Ideas?
Post the verbose output. Let's see what commands avrdude is sending.
It is probably the default sck clock speed set very low on the AVR-ISP500. If it is similar to other stk500v2 programmers then, it will use the last sck clock speed set from the programming software (AVRStudio or avrdude).
You can try using avrdude with a faster clock setting and see if it will keep that setting when using the Arduino IDE.
Try this (change the COM port to your setting):
avrdude -c stk500v2 -PCOM3 -B1 -p m328p -v
Note: the -B1 option will set the sck clock period to 1 microsecond.
Hopefully, if it is similar to other stk500v2 or avrispmkii programmers then it will save this sck clock setting in it's internal flash memory and use it as a new default for later use.
Edit: The problem is with the Arduino IDE does not utilize the software sck clock option with avrdude. Which limits the IDE to using whatever default sck clock the programmer uses. Hopefully they may add this feature to the IDE to be able to set the -B option to avrdude.
hiduino:
Ok, this fixed it. It now burns the bootloader in seconds, which is what I'm used to when I use an Uno as an ISP programmer.
I also unplugged the programmer, let it sit for a while, plugged it back in and tried burning a bootloader and it appears to have retained the setting. Speaking of, when I ran the above command, this is what it spewed back, in case either of you want to read it. The only thing that stood out to me was the sck_period being too small and it getting increased to 1.1 us instead:
avrdude: Version 5.10, compiled on Jan 19 2010 at 10:45:23
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\WinAVR-20100110\bin\avrdude.conf"
Using Port : COM2
Using Programmer : stk500v2
Setting bit clk period : 1.0
avrdude: stk500v2_set_sck_period(): p = 1.0 us too small, using 1.1 us
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 5 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel STK500 Version 2.x firmware
Programmer Model: STK500
Hardware Version: 2
Firmware Version Master : 2.10
Topcard : Unknown
Vtarget : 5.1 V
SCK period : 1.1 us
Varef : 5.1 V
Oscillator : 60.433 kHz
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f
avrdude: safemode: lfuse reads as FF
avrdude: safemode: hfuse reads as DA
avrdude: safemode: efuse reads as 5
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Why's the oscillator showing up as 60.433 kHz ? I'm assuming this isn't the same as the external 16MHz resonator that I have on the 328p? Other than that, I have no idea what I'm reading. I may have to go back to the datasheet and see if I can figure out what all those various parameters and variables mean.
And after configuring it to work with Atmel Studio 6, AND not being a C++ programmer, I was able to modify a blink program to blink two LEDs, one on what would be pin 13 (or PB5) and pin 1 (or PD1). Still trying to understand all the operators though ..
#define F_CPU 16000000 // AVR clock frequency in Hz, used by util/delay.h
#include <avr/io.h>
#include <util/delay.h>
int main() {
DDRB |= (1<<DDB5);
DDRD |= (1<<DDD1);
while (1) {
PORTD |= (1<<PORTD1);
_delay_ms(100);
PORTD &= ~(1<<PORTD1);
_delay_ms(100);
PORTB |= (1<<PORTB5);
_delay_ms(100);
PORTB &= ~(1<<PORTB5);
_delay_ms(700);
Now to figure out how to get Arduino libraries to play nice with AS6.0 ... And learn to write C++ ...
