[Solved] Please add in the IDE a TCP client connection to upload
Today we have many possibilities to create a TCP link, with the help of a small board ESP8266 (ESP-01) we can have a powerful remote programmer.
The ESP-Link Firmware allows a server to wait for a TCP connection. When the Client connects, a reset signal is made on the microcontroller.
The problem is that the user still relies on third party software, and they are expensive in view of the cost of a basic Arduino board.
ESP-Link Project (and instructions)
Thank you!
The Solution: Program from Arduino IDE - #394
Note: I tested with Linux Lubuntu 18.04 and IDE (1.8.5) was much faster than Windows 7
Flashing an attached Microcontroller
In order to connect through the esp-link to a microcontroller use port 23. For example, on linux you can use nc esp-hostname 23 or telnet esp-hostname 23.
Note that multiple connections to port 23 and 2323 can be made simultaneously. Esp-link will intermix characters received on all these connections onto the serial TX and it will broadcast incoming characters from the serial RX to all connections. Use with caution!
Flashing an attached AVR/Arduino
There are multiple options for reprogramming an attached AVR/Arduino microcontroller:
Use avrdude and point it at port 23 of esp-link. Esp-link automatically detects the programming sequence and issues a reset to the AVR.
Use avrdude and point it at port 2323 of esp-link. This is the same as port 23 except that the autodectection is not used and the reset happens because port 2323 is used
Use curl or a similar tool to HTTP POST the firmware to esp-link. This uses the built-in programmer, which only works for AVRs/Arduinos with the optiboot bootloader (which is std).
Use some serial port forwarding software, such as com2com, or hwvsp (you have to uncheck nvt in the settings when using the latter).
To reprogram an Arduino / AVR microcontroller by pointing avrdude at port 23 or 2323 you specify a serial port of the form net:esp-link:23 in avrdude's -P option, where esp-link is either the hostname of your esp-link or its IP address). This is instead of specifying a serial port of the form /dev/ttyUSB0. Esp-link detects that avrdude starts its connection with a flash synchronization sequence and sends a reset to the AVR microcontroller so it can switch into flash programming mode.
Note for Windows users: very recent avrdude versions on Windows support the -P option, while older ones don't. See the second-to-last bullet in the [avrdude 6.3 release notes]AVR Downloader/UploaDEr - News: AVRDUDE 6.3 released [Savannah]).
If I use the "ping esp-link" command at the prompt, the IP address will be displayed, I think it would be nice to have in IDE some way to inform this host name so that the correct avrdude command runs without the user needing to be reporting the IP address, because if the network operates with DHCP, IP can change.
This works:
(You need to leave the port speed selected in the esp-link settings)
D:\Arduino\hardware\tools\avr\bin>avrdude -v -p atmega328p -c arduino -P net:esp-link:23 -b 57600 -D -U flash:w:file.hex:i
Result:
avrdude: Version 6.3, compiled on Feb 17 2016 at 09:25:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "D:\Arduino\1- IDE\arduino-1.8.5-wind
ows1\Arduino A\hardware\tools\avr\bin\avrdude.conf"
Using Port : net:esp-link:23
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: ser_drain(): read error: ParÔmetro incorreto.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page
Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW Max
W ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 36
00 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 45
00 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 45
00 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 45
00 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 45
00 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 45
00 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0
0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0
0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: safemode: hfuse reads as 0
avrdude: safemode: efuse reads as 0
avrdude: reading input file "file.hex"
avrdude: writing flash (12176 bytes):
Writing | ################################################## | 100% 5.62s
avrdude: 12176 bytes of flash written
avrdude: verifying flash memory against file.hex:
avrdude: load data flash data from input file file.hex:
avrdude: input file file.hex contains 12176 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 24.07s
avrdude: verifying ...
avrdude: 12176 bytes of flash verified
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
avrdude done. Thank you.
(file.hex is the compiled file to be programmed into Arduino flash memory)
So perhaps all that is needed is to add a field there in the port selection part where the user can enter the Hostname so that avrdude can be configured with the correct command.
he only problem is that the esp-link has an error and doesn't propagate the mDns record as it should. otherwise you would see the network port in arduino IDE. the next problem is that Arduino IDE doesn't allow to enter the IP Address.
Hey, with the help of some messages I found on forums, I bundled a batch file to automatically send the file when exporting.
This is not the best way to resolve this, but you already avoid additional programs.
1- The file must be in the same folder as the sketch (INO file).
2- In "Hostname" should be the same as your ESP-link, use the ping command to test the esp-link, if it is dripping, it must be online.
3- In "AVRDUDE" Need to indicate avrdude.exe folder (full path in my case, IDE in zip file)
Note 1: The commands are tab sensitive, if it does not work try downloading the file.
Note 2: The *ino.eightanaloginputs.hex file, that was generated in the export will be erased, to wait for the next export. Backup: file.hex.
Note 3: To stop using Ctrl+C and confirm. Or close it.
Note 4: Sending data through the serial port made by arduino will cause the esp-link to block, but you can access the esp-link through the browser and reset the arduino at the time of upload. If you need to send data constantly, it may be best to use a second esp-link on ports other than the one used in programming.
Attention: Careful! Can not connect the esp8266 directly to 5V, I used a resistor / zener diode. In a test, by connecting directly to the arduino reset, my esp8266 has been permanently damaged.
file.bat (will run at a command prompt)
rem Hostname of your esp-link, you can change it
SET Hostname="esp-link"
rem
rem Location of avrdude.exe, need avrdude.conf in this folder too
SET AVRDUDE="D:\Arduino185\hardware\tools\avr\bin\avrdude"
rem
@echo off
:loop
for %%a in (*ino.eightanaloginputs.hex) do (
@echo %%a
@echo Trying to upload ...
@echo Please wait...
copy /Y %%a file.hex
%AVRDUDE% -p atmega328p -c arduino -P net:esp-link:23 -b 57600 -D -U flash:w:file.hex:i
@echo Deleting hex file...
del %%a
timeout /t 5
goto loop
Result:
Blink.ino.eightanaloginputs.hex
Please wait...
1 file (s) copied.
avrdude: ser_drain(): read error: Incorrect parameter. (Previous scketch was blocking the esp-link)
Reading | ################################################## | 100% 0.02s
avrdude: writing flash (948 bytes):
Writing | ################################################## | 100% 0.39s
avrdude: 948 bytes of flash written
avrdude: input file file.hex contains 948 bytes
Reading | ################################################## | 100% 1.96s
avrdude: 948 bytes of flash verified
autoUpload.zip (499 Bytes)
Sorry, the batch file has a problem:
The variable "Hostname" is not used:
To use the variable you must use the percentage symbol "%" delimiting the word,
To:
%AVRDUDE% -p atmega328p -c arduino -P net:%Hostname%:23 -b 57600 -D -U flash:w:file.hex:i
Thank you!
