The Arduino team is actually to blame for many, if not most of the broken libraries out there.
The biggest thing they they did that created these types of problems was during the 1.0 release.
With the 1.0 release they changed some of header files and some of the API interfaces; how the Print class interfaces to libraries that inherit it is one of those changes.
Prior to the 1.0 release there was no way for libraries to tell the core functions, like the Print functions about any status or error information.
1.0 changed that and started to support some return status information.
While having return values is a good thing, the way the Arduino team did the 1.0 release was absolutely terrible.
They made some significant changes to APIs and header file names and they did it between the final release candidate and the final release.
This is against all standard s/w development/release practices.
i.e. you don't make a major change that breaks compatibility with existing code without doing any sort of test release cycle.
And for sure you don't do this after a final release candidate without having at least another test release to allow the broader community to test it.
They did this after they had done alpha releases, beta release, and even a few release candidates with no subsequent testing release prior to its final release.
The changes they did broke 100% of all the 3rd party libraries. That isn't a mistype what they did broke 100% of all the existing 3rd party code out there.
And they did it knowingly and intentionally.
Several of us were very vocal against this decision and even offered them solutions that would have ensured that the vast majority of existing code could continue to operate.
They stated they preferred to break everything claiming that by breaking all existing code rather than providing any sort of backward compatibility, it would force people to fix their code to the new interfaces faster.
This took an eco system that had become very stable over the years and threw it into chaos and the community is still dealing with issues from that decision.
In this particular case the bug in the library wasn't directly do to the 1.0 changes but rather the way the author incorrectly implemented the return value.
Until recently (like the past couple of years) the Print class supported but ignored the return value.
Since the Print class ignored the return value, it didn't matter what value was returned.
Starting in IDE version 1.6.7 the Print class starting looking at the return value from the write() method.
If the return value from a library write() method is zero, Print will drop remaining characters in a multi-character string.
What can make this more complicated is that even though the Print class is a common service, it is implemented down in each specific core. i.e. down in the IDE AVR bundled core, and the 3rd party pic32core, and the DUE core, and the 3rd party teensy core etc...
So how it it is implemented can vary between board types since different boards can use different cores.
For example, Paul decided that he wasn't going to live with the "break the world" decision made when 1.0 was released.
So if you use a teensy board, many things that broke when using an UNO board, would still work with a teensy board.
Also because of the Print class being down in the core vs in a common area, it means that Print class checking return values is up to the individual core. Not all cores are updated at the same time and not all cores use the same code so depending on which core and which IDE version you have, there can be some variation of functionally when building code for different boards since different boards can use different cores.
With respect to the hd44780 library, I am the author, and normally I would advise using it as it has many capabilities that are not in any other lcd library. However, in this specific case, (using the ATtiny parts), I would advise caution.
The reason being that those parts have very limited flash and the hd4480 library will be larger than the library you are currently using. And this extra size can potentially be an issue in small flash sized environments.
Most of the reason is that code that is not being used is still being dragged into the linked image.
Unfortunately, there is no easy solution to fix this as it is due using C++ virtual functions and some decisions made by the gcc developers to remove some capabilities from the compiler that no longer allows removing unused C++ virtual functions.
I am very conscious of this and am working a solution for this but it will be a while as it requires changing the how things work under the hood in some very significant ways, hence it is not trivial.
So for the time being, while you can use the hd44780 library on the ATtiny parts, I would advise caution since it will use more flash than you may be comfortable with in that environment.
--- bill
