Ok, so use resistors to drop the voltage for output from the LM317T.
But since I am using a 1.5W solar panel, do I need to use a resistor with the LM317T?
The solar panel has typical output voltage of 4.5V and output current of 334ma.
Can I wire solar panel's positive(+) to pin 3(Vin) of LM317T
the LM317T pin 2(Vout) to the battery adapter's positive
then ground pin 1( ADJ) of the LM317T, as well as the negative of solar panel, and the negative of the battery pack?
The intent is to keep the battery pack from overcharging since the LM317T has a limiter in it. (not sure)
The batteries (how many in series? 2?) will draw probably try to draw too much current which will drop the voltage from the panel to below the dropout voltage of the 317. I tried this a while back.
Also you are using a linear regulator (the 317). This means that any over-voltage from the panel will be expended as heat from the regulator. If you used a switching regulator (~$4), that power would be converted into current for charging the batteries. Much more efficient and cooler too.
Use the LM317 in a current-limiting configuration and it should work, but you still need to make sure you don't charge the batteries past their max voltage.
