[SOLVED] setTimeout(), parseInt() and file reading from sd card
Hi.
I am using parseInt() to get some values froms a txt file.
Every thing is working but I still have that lag (delay) from the parseInt() function.
I have found that many are using setTimeout() to reduce that lag, but all of them are using Serial.setTimeout(), and I can't find any example showing how to use it for files stored on sd card.
Is there a way to use it in such case?
My files have always a fixed numbre of columns ex:
//for this example i would use 4 parsInt() to get the 4 values of every line at the same time
//i found that it to be simple and easy to work with that way
1;50;205;25;
663;744;88;52;
0;25;11;1;
20;550;50;22;
Or is there a better (without the delay) way to get data from such files?
parseInt() is a member of a class. Which class instance are you using to invoke parseInt()?
Reading an integer from a stream stops when the first non-digit (except a - sign) is found. So, you can make reading an integer almost instantaneous by making sure that there is something (like a space) following the integer in the stream.
As always, POST YOUR CODE.
Hi PaulS :smiley:
This is the function I am using to plot some graphs:
void drawcurve (int  prm, String filex) {
  tft.fillScreen(TFT_BLACK);
  affgraph = 1;
  float maxv = -32767;//was using integers
  float minv = 32767;
  myFile = SD.open(filex);
  if (myFile) {
    int zz = 0;
    while (myFile.available()) {
      int w1 = myFile.parseInt();
      int x1 = myFile.parseInt();
      int y1 = myFile.parseInt();
      int z1 = myFile.parseInt();
      switch (prm) {
        case 1:
          zz = x1; break;
        case 2:
          zz = y1; break;
        case 3:
          zz = z1; break;
      if (w1 != 0 || x1 != 0 || z1 != 0 || y1 != 0) {
        if ((zz / 100) > maxv) {
          maxv = (zz / 100);
        if ((zz / 100) < minv) {
          minv = (zz / 100);
  myFile.close();
  if (myFile) {
    float yy = 0;
      int w2 = myFile.parseInt();
      int x2 = myFile.parseInt();
      int y2 = myFile.parseInt();
      int z2 = myFile.parseInt();
      switch (prm) {
        case 1:
          yy = x2; break;
        case 2:
          yy = y2; break;
        case 3:
          yy = z2; break;
      int minvm = minv;
      int maxvm = maxv;
      maxvm = maxvm + 1;
      float ech = (maxv + 1 - minv) / 5;
      //  yy=x;
      if (w2 != 0 || x2 != 0 || z2 != 0 || y2 != 0) {
        Graph( w2, yy / 100, 40, 260, 400, 200, 0, 60, 10, minvm, maxvm, ech, "TC", "t", "temp", TFT_BLUE, TFT_WHITE, TFT_WHITE, TFT_WHITE, TFT_BLACK, affgraph);//custom plotting function
    myFile.close();
  else {
    TFTPrint("can't find " + filex, 0, 150, 2, 2, TFT_BLACK, TFT_RED);
I first choose the parameter i want. Then arduino looks into the file twice:
  • 1 to look for max and min values of the parameter I chose (for scaling)
  • 2 to plot the graphic
The code is working, but i have about 3s delay before I get the graph (reading file?), and another 3s after gettinng the graph (timeout?).
Add some Serial.print() statements in the code, and print the value of millis() after a suitable prefix, to show where the code is spending the time. I don't think that you'll find that it is in the parseInt() function.
Opening and closing files is not instantaneous. Calling the Graph() function probably isn't, either.
PaulS:
I will try that, thanks.
What i'm worried about is the delay after the graph is plotted (the file is closed and the Graph() function has finished its tastk).
I read that parseInt() has a defaut time out of 1000ms, and using setTimeout (well, it is Serial.setTimeout() as every example i saw was about serial input) can be used to lower that delay (ex: Serial.setTimeout(10);).
The setTimeout() method is actually part of the same class that parseInt(), etc. are in. So, myFile.setTimeout() will work.
But, before you set it to a small value, try setting it to a large value, and see if you see any change. I do not think that parseInt() is what is taking the time. If you set the time out value to 10 seconds (the default is one second), and the program takes no longer, then setting it to a smaller value will not speed the program up.
PaulS:
Hi again. I tried that, but nothing changed. So I tried the millis() method you suggested:
  • First, I called the Serial.println(millis()) just when the fuction starts, just before calling the file to open, just after that, just before calling the file to close and just after that. And the result is:
millis just when draw curve starts :
23486
millis before first file opening:
23529
millis after first file opening:
23555
millis just before first file close:
27621
millis before second file opening:
27637
millis after second file opening:
27680
millis before second file closing:
31795
millis after second file closing:
31808
After that i can say that calling the function, the file to open or to close does not take much time.
So I called the Serial.println(millis()) after eatch file treatment (inside while(myFile.available())) and I got this :
16321
16364
16389
millis after every line treatement (file1):
16433
16487
16541
16595
16649
16703
16757
16812
16866
16919
16973
17028
17082
17136
17189
17244
17298
17352
17406
17461
17514
17568
17623
17677
17731
17784
17839
17893
17947
18001
22009
22035
22080
22123
millis after every line treating and plotting:
22180
22238
22295
22352
22410
22466
22523
22581
22638
22695
22753
22810
22866
22924
22981
23038
23096
23153
23211
23267
23324
23382
23439
23496
23554
23611
23667
23725
23782
23839
27846
27873
27917
As you can see, there is a delay (about 4000ms) between the treatment last line treatment and the file closing. (I am calling parseInt 4 times * 4 timeout = 4000ms?).
What do you think?.
(This is the code with millis() printing: )
  Serial.println("millis just when draw curve starts :");
  Serial.println(millis());
  //TFTPrint("thisparam:"+String(prm), 240, 160, 2, 2, TFT_WHITE, TFT_RED);
  affgraph = 1;
  float minv = 32767;
  Serial.println("millis before first file opening:");
  Serial.println("millis after first file opening:");
  if (myFile) {
    int zz = 0;
      switch (prm) {
        case 1:
          zz = x1; break;
        case 2:
          zz = y1; break;
        case 3:
          zz = z1; break;
          maxv = (zz / 100);
          minv = (zz / 100);
      Serial.println("millis after every line treatement (file1):");
  Serial.println("millis just before first file close:");
  myFile.close();
  Serial.println("millis before second file opening:");
  Serial.println("millis after second file opening:");
  if (myFile) {
    float yy = 0;
      switch (prm) {
        case 1:
          yy = x2; break;
        case 2:
          yy = y2; break;
        case 3:
          yy = z2; break;
      int minvm = minv;
      int maxvm = maxv;
      maxvm = maxvm + 1;
      //  yy=x;
        Graph( w2, yy / 100, 40, 260, 400, 200, 0, 60, 10, minvm, maxvm, ech, "Light", "Time", "L it", TFT_BLUE, TFT_WHITE, TFT_WHITE, TFT_WHITE, TFT_BLACK, affgraph);
        // TFTPrint(String(maxv), 100, 150, 2, 2, TFT_BLACK, TFT_RED);
        // TFTPrint(String(minv), 100, 180, 2, 2, TFT_BLACK, TFT_RED);
        //  TFTPrint(String(minvm), 100, 210, 2, 2, TFT_BLACK, TFT_RED);
        //   TFTPrint(String(maxvm), 100, 240, 2, 2, TFT_BLACK, TFT_RED);
        //     TFTPrint(String(ech), 100, 270, 2, 2, TFT_BLACK, TFT_RED);
      Serial.println("millis after every line treating and plotting:");
    Serial.println("millis before second file closing:");
    myFile.close();
    Serial.println("millis after second file closing:");
  else {
Hi again. Solved :smiley:
myFile.setTimeout() solved it, I just tried it at first in the loop function or after file oppening and it didn't work.
I tried it just before starting myFile.parseInt() and it worked :slight_smile:
Thank you for the help PaulS ^^
Apparently, the last record of your file does not contain a carriage return and/or line feed.
PaulS:
Hi PaulS. I don't know what is carriage return or line feed :smiley:
fjtheknight:
RogerPate_stackoverflow:
Carriage return means to return to the beginning of the current line without advancing downward. The name comes from a printer's carriage, as monitors were rare when the name was coined. This is commonly escaped as "\r", abbreviated CR, and has ASCII value 13 or 0x0D.
Linefeed means to advance downward to the next line; however, it has been repurposed and renamed. Used as "newline", it terminates lines (commonly confused with separating lines). This is commonly escaped as "\n", abbreviated LF or NL, and has ASCII value 10 or 0x0A. CRLF (but not CRNL) is used for the pair "\r\n".
Form feed means advance downward to the next "page". It was commonly used as page separators, but now is also used as section separators. (It's uncommonly used in source code to divide logically independent functions or groups of functions.) Text editors can use this character when you "insert a page break". This is commonly escaped as "\f", abbreviated FF, and has ASCII value 12 or 0x0C.
I know now what they are, but still don't know how to use them.
[When you typed the data into the file,
at the end of the first three
records, you hit the enter key, to add a carriage return and line feed.
On the last record, you appear not to have.]
So, when reading the data, there is nothing after the last digit of the last value to tell parseInt() to stop reading. So, it is sitting around, hoping that more data will appear in the file.
Edit the file. At the end of the last record, hit the enter key, so that there are 4 CRs and 4 LFs in the file, not just three of each.
PaulS:
I am using a function to read some sensors (3) every 5 seconds and log data automaticly into an sd card file.
I am making a string containing time and the sensors readings.
Isn't File.println() supposed to do that? or should i add something to the string end?
void logData() {
  File dataFile = SD.open(filename, FILE_WRITE);
  if (dataFile) {
    String datastring = "";
    datastring = String(logtime) + ";" + String((int)(CTemp * 100)) + ";" + String((int)(CHum * 100)) + ";" + String((int)(CLight * 100));// i have just realized that my string does not have a ";" at the end
    dataFile.println(datastring);
    dataFile.close();
That is NOT what the code is doing. There is NO excuse for buffering the data in a useless String, when the SD class buffers data already.
Yes. Perhaps the issue is that the last cr/lf combo triggers an attempt to read three more values that don't exist.
That's why I never use parseInt(). I prefer to have complete control over what is happening.
