[solved] Testing for a character input via serial monitor
New to Arduino, I'm trying to figure out how to test a character input I make via the serial monitor in the Arduino IDE.
I think my problem is with the input == "u", hopefully it's an easy fix to make this comparison properly.
  if (Serial.available()) {
    input = Serial.read();
    Serial.print("You typed: '");
    Serial.print(input);
    Serial.println("'");
    if (input == "u") {  // strings match
      Serial.println(" got a u");
      Serial.println("was not interesting");
The code that you posted does not include the declaration of the input variable
My guess is that it is a char. If so then use
if (input == 'u')
to do the comparison
Please post your complete sketch
'u' not "u"
'u' instead of "u" fixed it. Thank you very much.
Do you understand what the problem was ?
In future please post your whole sketch if you have a question
Other than the syntax, no I do not. It was declared as char as you guessed. I do not understand the difference in 'u' and "u".
'u' is a single character. A char can only ever be a single character
"u" is a 2 character array. 1 character for the string of characters, in this case a single char, and a second one to hold the zero that signals the end of the string. A C style string can hold multiple characters
chars are compared using ==
strings are compared using the strcmp() function
'u' is a character and "u" is a string. Does that make sense to you?
Thank you for that detail, much appreciated. For my reference and education, can you show me how a comparison would look using strcmp and the string "uax" for example. Would it be:
if (strcmp(input),"uax") == 0) {
//True, do stuff
I saw strncmp too when I was trying to get this to work originally, but didn't have any sucess with it.
The syntax that you are looking for is
if (strcmp(input, "uax")) == 0  //true if the strings match
  //execute this code
However, for this to work the input variable must be a zero terminated array of chars. Please post your code that creates this array from user input
The strncmp() function works the same way but limits the search for a match to the number of characters specified
if (strncmp(input, "uax", 2))   //match the first 2 characters of the strings
I'm just typing in the serial monitor. That's whats creating the input. Whole sketch here. I see that I can't use it as listed for the "uax" example string as that pulls it in one character at a time.
char input;
  // Start the serial port
  Serial.println("Enter command: ");
    if (input == 'u')
      {  // strings match
      Serial.println("Matched input = u");
      // do stuff triggered by u
    // else if (strcmp(input, "uax") == 0)
    //   {  //true if the strings match
    //    Serial.println("Matched input = aux");
      Serial.println("no matches");
      // don't do anything
See Serial input basics - updated
Very helpful, thank you for that link.
