the code does not work, someone try to correct it?
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
int sensorPin = A0; // select the input pin for the potentiometer
int ledPin = 3; // select the pin for the LED
int sensorValue = 0; // variable to store the value coming from the sensor
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
if (DEC> 55) {
lcd.print(" > .. < ");
if DEC< 55) {
lcd.print(" @ .. @");
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
if (DEC> 30) {
lcd.print(" ________ ");
if (DEC< 30) {
lcd.print(" I______I ");
// stampe delle temperature ogni secondo
delay(100);
it should be a face on an LCD screen that changes according to the noise around it.
tanks.
