someone!!!!!!!, please can help me to do a simple coding for smart outlet
its for my final year project. i use arduino uno to do that project and socket,relay . the project works like, i can turn on/off the outlet/socket using my phone. which looks like this:
https://www.google.com/url?sa=i&source=images&cd=&cad=rja&uact=8&ved=2ahUKEwiAoafvztngAhVcknAKHX5qDKcQjRx6BAgBEAU&url=http%3A%2F%2Fwww.circuitbasics.com%2Fbuild-an-arduino-controlled-power-outlet%2F&psig=AOvVaw3mNP_x-cImyzrnSJNSMKDm&ust=1551277956683295
and in that project i want to put 2 output 1 is a socket and than another output is a lamp which I can control using phone
this example of a project I mean
one more thing
please give your pinion which I should use in this project to connect this project to the phone wifi or bluetooth.
SORRY FOR MY BAD ENGLISH , I WORK HARD TO WRITE THIS IN ENGLISH
(deleted)
If you have successfully controlled one socket from your phone then you just need to repeat the same procedure for your lamp. At the second output place a relay, which will act as an automatic switch and output of relay will be connected to lamp.
I think bluetooth will be better as its easy to handle as compared to Wifi. First go for bluetooth and if you completed that then you should work on wifi.
Unless you are really familiar with mains wiring, I would suggest that you have someone who is to help you. Mains power is deadly and can cause fires if improperly used. Connecting too large of a load to the socket can fry the relay and who knows what else. Be careful.
