Please understand i am new and may not understand technical answers.
Two sonic sensors at 30 degrees facing away from each other.
Right sensor detects object 4 servos move right
Left sensor detects object 4 servos move left
No object stay center
both detect, left two move right and right two move left
What happens in simulation: servos move right 90 degrees and stop. serial monitor says object detected from right sensor and repeats
Thanks
// Define pins for the ultrasonic sensors
const int rightSensorTrigPin = 2;
const int rightSensorEchoPin = 3;
const int leftSensorTrigPin = 4;
const int leftSensorEchoPin = 5;
// Define servo objects
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
// Define pins for the servo motors
const int servo1Pin = 6;
const int servo2Pin = 7;
const int servo3Pin = 8;
const int servo4Pin = 9;
// Declare center function
void centerServos() {
// Set all servos to 45 degrees
servo1.write(45);
servo2.write(45);
servo3.write(45);
servo4.write(45);
// Delay for 1 second to allow servos to reach position
// Initialize serial communication
while (!Serial) {} // Wait for the serial connection to be established
// Attach servo objects to the corresponding pins
servo1.attach(servo1Pin);
servo2.attach(servo2Pin);
servo3.attach(servo3Pin);
servo4.attach(servo4Pin);
// Initialize ultrasonic sensors
pinMode(rightSensorTrigPin, OUTPUT);
pinMode(rightSensorEchoPin, INPUT);
pinMode(leftSensorTrigPin, OUTPUT);
pinMode(leftSensorEchoPin, INPUT);
// Read distance measurements from the ultrasonic sensors
int rightDistance = readDistance(rightSensorTrigPin, rightSensorEchoPin);
int leftDistance = readDistance(leftSensorTrigPin, leftSensorEchoPin);
// Determine the direction to turn the servo motors based on the sensor readings
if (rightDistance < 20 && leftDistance < 20) {
Serial.println("Both sensors detected objects, turning right and left");
turnRightAndLeft();
} else if (rightDistance < 20) {
Serial.println("Right sensor detected an object, turning right");
turnRight();
} else if (leftDistance < 20) {
Serial.println("Left sensor detected an object, turning left");
turnLeft();
Serial.println("No objects detected, centering");
centerServos();
int readDistance(int trigPin, int echoPin) {
// Send a 10us pulse to the ultrasonic sensor to trigger a measurement
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Read the time it takes for the echo to return
int duration = pulseIn(echoPin, HIGH);
// Convert the duration to distance in centimeters
int distance = duration / 58;
return distance;
void turnRight() {
servo1.write(90);
servo2.write(90);
servo3.write(90);
servo4.write(90);
void turnLeft() {
servo1.write(0);
servo2.write(0);
servo3.write(0);
servo4.write(0);
void turnRightAndLeft() {
servo1.write(0);
servo2.write(0);
servo3.write(90);
servo4.write(90);
servo1.write(90);
servo2.write(90);
servo3.write(0);
servo4.write(0);
type or paste code here
