I've used this library for several years and now it stops working. Using Sparkfun BME280 Ver 2.0.9, Arduino IDE 2.3.2 and Espressif ESP32 ver. 2.0.14.
When I run the Example 1 Basic Readings I get and error "The sensor did not respond. Please check wiring." I've used several different wire jumpers and different BME280 boards - all the same. Did a I2C scan and port 0x76 is there.
Any suggestions? I've found the Expressif ESP32 board software to be a problem before. LEDControl library works with version ESP32 version 1.0.6 but not of the 2.x versions.
Thanks, Theron Wierenga
