Hi there,
I am trying to get the example code working with the following CAN shield: CAN-BUS Shield Hookup Guide - SparkFun Learn .
After getting the initialisation working with the Arduino UNO (actually not arduino but a knock off UNO), it doesn't give me anything on the CAN analyser tool when I try to run the example code below:
#include <Canbus.h>
#include <defaults.h>
#include <global.h>
#include <mcp2515.h>
#include <mcp2515_defs.h>
//********************************Setup Loop*********************************//
Serial.println("CAN Write - Testing transmission of CAN Bus messages");
if(Canbus.init(CANSPEED_500)) //Initialise MCP2515 CAN controller at the specified speed
Serial.println("CAN Init ok");
Serial.println("Can't init CAN");
//********************************Main Loop*********************************//
tCAN message;
message.id = 0x631; //formatted in HEX
message.header.rtr = 0;
message.header.length = 8; //formatted in DEC
message.data[0] = 0x40;
message.data[1] = 0x05;
message.data[2] = 0x30;
message.data[3] = 0xFF; //formatted in HEX
message.data[4] = 0x00;
message.data[5] = 0x40;
message.data[6] = 0x00;
message.data[7] = 0x00;
mcp2515_bit_modify(CANCTRL, (1<<REQOP2)|(1<<REQOP1)|(1<<REQOP0), 0);
mcp2515_send_message(&message);
Before you say the CAN analyser tool may be broken, I also tried with this code (MCP_CAN_lib/CAN_send.ino at master · coryjfowler/MCP_CAN_lib · GitHub) from a different library and it gave me the error message in the arduino serial moniter "Error Sending Message...".
I am using a female DB9 to DB9 cable from the CAN shield to the CAN analyser tool. Is it maybe that this is the problem? Do I have to reconfigure the jumpers in 6c here: CAN-BUS Shield Hookup Guide - SparkFun Learn ? If so, how exactly do I do that, it says something about soldering but it's not quite clear to me how I should solder those pads.
Another idea I had was that the lack of termination resistors is causing the problem, because as far as I understand there are no termination resistors included in the shield, correct? If so, how do I add them if I want to use the DB9 cable to send receive?
Attached is a picture of my setup. There is an LCD attached, but it is not doing anything for the moment. Any help is greatly appreciated.
