Hello,
I've been using the Sparkfun Library for a pressure sensor with Arduino Micro and Nano with no problem. But I don't know why, with Arduino Nano Every the library breaks with following error.
Compiling sketch...
/Users/angel/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DAVR_NANO_4809_328MODE -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/angel/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.8/cores/arduino/api/deprecated -I/Users/angel/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.8/cores/arduino -I/Users/angel/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.8/variants/nona4809 -I/Users/angel/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.8/libraries/Wire/src /Users/angel/Library/Caches/arduino/sketches/F61EF9A2AC2B5627C718CBAD8F6DF99F/sketch/SparkFun_MicroPressure.cpp -o /Users/angel/Library/Caches/arduino/sketches/F61EF9A2AC2B5627C718CBAD8F6DF99F/sketch/SparkFun_MicroPressure.cpp.o
/Users/angel/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DAVR_NANO_4809_328MODE -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/angel/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.8/cores/arduino/api/deprecated -I/Users/angel/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.8/cores/arduino -I/Users/angel/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.8/variants/nona4809 -I/Users/angel/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.8/libraries/Wire/src /Users/angel/Library/Caches/arduino/sketches/F61EF9A2AC2B5627C718CBAD8F6DF99F/sketch/desktop_kids_V02.ino.cpp -o /Users/angel/Library/Caches/arduino/sketches/F61EF9A2AC2B5627C718CBAD8F6DF99F/sketch/desktop_kids_V02.ino.cpp.o
In file included from /Users/angel/Library/Caches/arduino/sketches/F61EF9A2AC2B5627C718CBAD8F6DF99F/sketch/desktop_kids_V02.ino.cpp:1:0:
/Users/angel/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.8/cores/arduino/Arduino.h:101:12: error: expected identifier before numeric constant
#define PA 0
/Users/angel/Downloads/SP/Tools/Desktop_Kids/desktop_kids_V02/SparkFun_MicroPressure.h:22:3: note: in expansion of macro 'PA'
PA,
/Users/angel/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.8/cores/arduino/Arduino.h:101:12: error: expected '}' before numeric constant
#define PA 0
PA,
/Users/angel/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.8/cores/arduino/Arduino.h:101:12: error: expected unqualified-id before numeric constant
#define PA 0
PA,
In file included from /Users/angel/Downloads/SP/Tools/Desktop_Kids/desktop_kids_V02/desktop_kids_V02.ino:2:0:
/Users/angel/Downloads/SP/Tools/Desktop_Kids/desktop_kids_V02/SparkFun_MicroPressure.h:28:1: error: expected declaration before '}' token
In file included from /Users/angel/Downloads/SP/Tools/Desktop_Kids/desktop_kids_V02/SparkFun_MicroPressure.h:2:0,
from /Users/angel/Downloads/SP/Tools/Desktop_Kids/desktop_kids_V02/SparkFun_MicroPressure.cpp:10:
#define PA 0
PA,
#define PA 0
PA,
#define PA 0
PA,
In file included from /Users/angel/Downloads/SP/Tools/Desktop_Kids/desktop_kids_V02/SparkFun_MicroPressure.cpp:10:0:
Using library Wire at version 1.0 in folder: /Users/angel/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.8/libraries/Wire
exit status 1
Compilation error: expected declaration before '}' token
Do you know why am I getting this error? If I select Arduino Micro in the GUI the sketch compiles perfectly, but of course it cannot upload it to the board.
Here is the full sketch:
#include "SparkFun_MicroPressure.h"
int counter = 0;
unsigned long delayTime = 50;
int step = 1;
int sign = 1;
int pumpPort = 3;
int evArray[] = {9, 10, 11, 12};
int evId = 0;
int evAmount = sizeof(evArray)/sizeof(int);
float pressure = 0.0;
SparkFun_MicroPressure mpr; // Use default values with reset and EOC pins unused
pinMode(pumpPort, OUTPUT);
for(int evId = 0; evId < evAmount; evId++ ){
pinMode(evArray[evId],OUTPUT);
if(!mpr.begin())
Serial.println("Cannot connect to MicroPressure sensor.");
while(1);
counter = counter + (sign*step);
if (counter > 255){
counter = 255 - (2*step);
sign = sign * -1;
if (counter <=0){
counter = step;
sign = sign * -1;
pressure = mpr.readPressure(BAR)-1;
Serial.print("Counter= ");
Serial.print(counter);
Serial.print(", Pressure=");
Serial.println(pressure);
pumpOn(counter);
delay(delayTime);
if (counter >= (255-step)){
for( evId = 0; evId < evAmount; evId++){
Serial.print("EV: ");
Serial.println(evArray[evId]);
ev_On(evArray[evId]);
ev_Off(evArray[evId]);
void pumpOn(int pwm){
analogWrite(pumpPort, pwm);
void ev_On(int evPort){
digitalWrite(evPort, HIGH);
void ev_Off(int evPort){
digitalWrite(evPort, LOW);
Sparkfun.cpp code
/* This is a library for the Qwiic MicroPressure Sensor, which can read from 0 to 25 PSI. By: Alex Wende Date: July 2020 License: This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license). Feel like supporting our work? Buy a board from SparkFun! */ #include "SparkFun_MicroPressure.h" /* Constructor and sets default values. - (Optional) eoc_pin, End of Conversion indicator. Default: -1 (skip) - (Optional) rst_pin, Reset pin for MPR sensor. Default: -1 (skip) - minimumPSI, minimum range value of the sensor (in PSI). Default: 0 - maximumPSI, maximum range value of the sensor (in pSI). Default: 25 */ SparkFun_MicroPressure::SparkFun_MicroPressure(int8_t eoc_pin, int8_t rst_pin, uint8_t minimumPSI, uint8_t maximumPSI) { _eoc = eoc_pin; _rst = rst_pin; _minPsi = minimumPSI; _maxPsi = maximumPSI; } /* Initialize hardware - deviceAddress, I2C address of the sensor. Default: 0x18 - wirePort, sets the I2C bus used for communication. Default: Wire - Returns 0/1: 0: sensor not found, 1: sensor connected */ bool SparkFun_MicroPressure::begin(uint8_t deviceAddress, TwoWire &wirePort) { _address = deviceAddress; _i2cPort = &wirePort; if(_eoc != -1) { pinMode(_eoc, INPUT); } if(_rst != -1) { pinMode(_rst, OUTPUT); digitalWrite(_rst,LOW); delay(5); digitalWrite(_rst,HIGH); delay(5); } _i2cPort->beginTransmission(_address); uint8_t error = _i2cPort->endTransmission(); if(error == 0) return true; else return false; } /* Read the status byte of the sensor - Returns status byte */ uint8_t SparkFun_MicroPressure::readStatus(void) { _i2cPort->requestFrom(_address,1); return _i2cPort->read(); } /* Read the Pressure Sensor Reading - (optional) Pressure_Units, can return various pressure units. Default: PSI Pressure Units available: - PSI: Pounds per Square Inch - PA: Pascals - KPA: Kilopascals - TORR - INHG: Inch of Mercury - ATM: Atmospheres - BAR */ float SparkFun_MicroPressure::readPressure(Pressure_Units units) { _i2cPort->beginTransmission(_address); _i2cPort->write((uint8_t)0xAA); _i2cPort->write((uint8_t)0x00); _i2cPort->write((uint8_t)0x00); _i2cPort->endTransmission(); // Wait for new pressure reading available if(_eoc != -1) // Use GPIO pin if defined { while(!digitalRead(_eoc)) { delay(1); } } else // Check status byte if GPIO is not defined { uint8_t status = readStatus(); while((status&BUSY_FLAG) && (status!=0xFF)) { delay(1); status = readStatus(); } } _i2cPort->requestFrom(_address,4); uint8_t status = _i2cPort->read(); //check memory integrity and math saturation bits if((status & INTEGRITY_FLAG) || (status & MATH_SAT_FLAG)) { return NAN; } //read 24-bit pressure uint32_t reading = 0; for(uint8_t i=0;i<3;i++) { reading |= _i2cPort->read(); if(i != 2) reading = reading<<8; } //convert from 24-bit to float psi value float pressure; pressure = (reading - OUTPUT_MIN) * (_maxPsi - _minPsi); pressure = (pressure / (OUTPUT_MAX - OUTPUT_MIN)) + _minPsi; if(units == PSI) return pressure; //PSI else if(units == PA) return pressure*6894.7573; //Pa (Pascal) else if(units == KPA) return pressure*6.89476; //kPa (kilopascal) else if(units == TORR) return pressure*51.7149; //torr (mmHg) else if(units == INHG) return pressure*2.03602; //inHg (inch of mercury) else if(units == ATM) return pressure*0.06805; //atm (atmosphere) else if(units == BAR) return pressure*0.06895; //bar else return pressure; //PSI }
Sparkfun .h code
#if (ARDUINO >= 100) #include "Arduino.h" #else #include "WProgram.h" #endif #include <Wire.h> #define DEFAULT_ADDRESS 0x18 #define MAXIMUM_PSI 25 #define MINIMUM_PSI 0 #define BUSY_FLAG 0x20 #define INTEGRITY_FLAG 0x04 #define MATH_SAT_FLAG 0x01 #define OUTPUT_MAX 0xE66666 #define OUTPUT_MIN 0x19999A enum Pressure_Units { PSI, PA, KPA, TORR, INHG, ATM, BAR }; class SparkFun_MicroPressure { public: SparkFun_MicroPressure(int8_t eoc_pin=-1, int8_t rst_pin=-1, uint8_t minimumPSI=MINIMUM_PSI, uint8_t maximumPSI=MAXIMUM_PSI); bool begin(uint8_t deviceAddress = DEFAULT_ADDRESS, TwoWire &wirePort = Wire); uint8_t readStatus(void); float readPressure(Pressure_Units units=PSI); private: int8_t _address; int8_t _eoc, _rst; uint8_t _minPsi, _maxPsi; TwoWire *_i2cPort; };
