QFAN:
I soldered the headers myself. It's my first time soldering so I don't know if the connections are good or if I burnt some lines printed on the PCB.
Well checkout for any dry solder. I had a dry solder when I first tried a host shield.
QFAN:
I did not try adding an external power source. How do I do that?
QFAN:
QFAN:
Power up Arduino using an external power supply.
Checked with multimeter, pins seem to have good connections to corresponding test points shown on design file USBHostShield-v13.brd.
I also added external battery pack (5*AA) so I get 5.8V at Vin with rechargeable and 7V with alkaline.
The test still fails with the same error Value written: 01 read: 00.
QFAN:
Is this the loopback test? If yes then you can skip it.
Also the library is not officially compatible with the Sparkfun shield.
Yes, but since the library cannot Init successfully, skipping the test doesn't help.
Still, I can't tell if it's the problem of wrong library or I have a defective card. Probably I should start reading the manual of the actual chip used and try to start from there.
I have a couple of things I had ask to about the integration of my USB Barcode Scanner to the Arduino Mega 2560.
This is what I have done so far:
Placed my Sparkfun USB Hostshield onto my Mega
Jumpered RST to D7
Changed the following in Usb.h
// typedef MAX3421e<P10, P9> MAX3421E; // Official Arduinos (UNO, Duemilanove, Mega, 2560 <<--- Modified line
typedef MAX3421e<P53, P9> MAX3421E; // Official Arduinos (UNO, Duemilanove, Mega, 2560
However, I still end up with the following result when I run it:
Circuits At Home 2011
USB Host Shield Quality Control Routine
Reading REVISION register... Die revision invalid. Value returned: 00
Unrecoverable error - test halted!!
0x55 pattern is transmitted via SPI
Press RESET to restart test
I got the same problem as many. I got the revised USB Host Shield by Sparkfun and got errors on the board test. I tried the jumper D7 to reset trick and it didnt worked with and without external power. I dont know what to do next. Thanks.
I know this is a long time but I have the same issue and spent weeks trying to resolve it as I need it for my project. I am trying to get the hub_demo example to work as I want to connect a USB hub to my shield but it's not working.
I have jumpered D7 to RST and also used a seperate power supply for the Arduino and hub but still no result. I need help urgently, please.
Hi everyone. I try to deal with HID devices and library USB_Host_Library 2. I connect a keyboard with a touchpad and run the example USBHIDBootKbdAndMouse. The keyboard works, the touchpad doesn't. What could be the problem?
