SPI 32 bits output.
Hi Guys!!
I am having some problems getting 32bits.
Any Idea how do i code it? I need a straight 32bits instead of 4x8bits.
Please advise!
Thank You!
Is there a difference between 32 bits and 4*8 with SPI.transfer ?
What kind of chip is it ?
What's the difference?, except a slight pause between bytes that should not matter to anything.
Anyway the answer is no, you cannot do a 32-bit shift on an 8-bit CPU using the SPI hardware. You can if you write a modified version of shiftOut().
Rob
Can do the SPI transfers really fast, will not see any break.
Set SPI divisor to 2 (8 MHz transfers)
Then:
// top of your sketch:
#include <SPI.h>
#define nop asm volatile ("nop")
// this in loop () to send the data out
digitalWrite (ssPin, LOW);
SPDR = array[0]; nop;nop;nop;nop;nop;nop;nop;nop;nop;nop;nop;nop;nop;nop;nop;
digitalWrite (ssPin, HIGH);
Hi Guys,
Thanks for the replies!
May I know how do I modify from this to transfer faster to not see any break?
Thanks!
unsigned long Transfer(unsigned long value)
FourByte data = {value};
for(byte i = 0; i < 4; i++)
data.bit8 = SPI.transfer(data.bit8*);*
* return data.bit32;*
* unsigned long address = 0x00100000; //swap*
digitalWrite(53, HIGH); //output SEN high
Transfer(address);
digitalWrite(53,LOW); // Set SEN LOW once 32bits is sent
CODE TAGS please. And show all the code.
Well Crossroads gave one option. Your function looks a little sus but we need to see ALL the code, how do we know what a "FourByte" is?
Rob
Hi Guys!
Sorry This is the full code!
This can output 4x8bits.
#include <SPI.h> // Links prewritten SPI library into the code
union FourByte
unsigned long bit32;
unsigned int bit16[2];
unsigned char bit8[4];
pinMode(53, OUTPUT); // Set SPI pins to be outputs (slave select)
pinMode(52, OUTPUT); // clock
pinMode(51, OUTPUT); // Data
digitalWrite(2, HIGH); // Set Arduino pull-up resistors active
digitalWrite(3, HIGH); // This sets an internal to the chip
digitalWrite(4, HIGH); // pull-up resistor on so an unconnected pin
digitalWrite(5, HIGH); // is reliably at logic 1
digitalWrite(6, HIGH);
digitalWrite(7, HIGH);
digitalWrite(8, HIGH);
digitalWrite(9, HIGH);
digitalWrite(53, HIGH); // output High SEN
pinMode(52, HIGH);
pinMode(50, HIGH);
digitalWrite(11, HIGH);
digitalWrite(13, HIGH);
SPI.begin(); // Initialize SPI parameters
SPI.setBitOrder(MSBFIRST); // MSB to be sent first
SPI.setDataMode(SPI_MODE0); // Set for clock rising edge
SPI.setClockDivider(SPI_CLOCK_DIV2); // Set clock divider (optional)
digitalWrite(53, LOW);
Transfer(address);
And the CODE tags? Without them the code loses important details. (click on the # button in the toolbar when editing the post)
Rob
Can this work?
union FourByte
  pinMode(52, HIGH);
  pinMode(50, HIGH);
    data.bit8[i] = SPI.transfer(data.bit8[i]);
  return data.bit32;
 Transfer(address);
I think that will work, but why the union?
What happened to this?
Rob
Somehow my chip need to read it in a string. Is it possible and how to change my code in order to enable lesser delay between each 8bits.
Yes - get rid of the for:loop here:
    data.bit8 = SPI.transfer(data.bit8);
  return data.bit32;
Each pass thru the loop adds ~12uS break between transfers.
Get rid of SPI.transfer - the library waits for an interupt to come back before it sends the next byte.
Put your data into an array and send it out like I did.
aboveall:
somehow my chip need to read it in a string.
What chip is this? I've never seen one that would object to a small delay between bytes, that's one of the points about a synchronous protocol. So
somearray[0] = SPI.transfer (somearray[0]);
somearray[1] = SPI.transfer (somearray[1]);
somearray[2] = SPI.transfer (somearray[2]);
somearray[3] = SPI.transfer (somearray[3]);
should be all you need, or if you really need no break use Crossroad's example.
I assume you are also receiving data from the device? Otherwise there's no point saving the return value from transfer().
Rob
You have an 8-bit computer. Anything that you do with your 32 bit value, will be processed as 4x8 bits.
You entire problem seems to be wholly misconceived.
so I would just need to remove the for loop? And input this?
How do I go about setting the hex address in each array?
I would track them as 4 bytes.
You could maintain it as a long, unsigned long, with any number of ways to break it into 4 bytes for sending.
What HEX address?
And you haven't answered any of my previous questions. They are the words before a ?
Rob
Sorry, as I said I need as less delay as possible. What do you mean word before a?
Cross roads: May I know how you write them? Like if I need this string 0x010000001
Thanks! Sorry I am very new to this.
aboveall:
You had a good example of this on the next line when you wrote:-
The words before the ? were:-
It was a question.
? is called a question mark, mainly because it marks a question.
Help pls!
Thanks!
