OK, so i am really stuck and won't have much hair left soon! I am no longer trying to make the code in the above post work (using the SPI_anything.h header file). Instead i am focusing on the first example.
MASTER_ORIGINAL
// Written by Nick Gammon
// February 2011
#include <SPI.h>
void setup (void)
digitalWrite(SS, HIGH); // ensure SS stays high for now
// Put SCK, MOSI, SS pins into output mode
// also put SCK, MOSI into LOW state, and SS into HIGH state.
// Then put SPI hardware into Master mode and turn SPI on
SPI.begin ();
// Slow down the master a bit
SPI.setClockDivider(SPI_CLOCK_DIV8);
} // end of setup
void loop (void)
char c;
// enable Slave Select
digitalWrite(SS, LOW); // SS is pin 10
// send test string
for (const char * p = "Hello, world!\n" ; c = *p; p++)
SPI.transfer (c);
// disable Slave Select
delay (1000); // 1 seconds delay
} // end of loop
SLAVE_ORIGINAL
// February 2011
#include <SPI.h>
char buf [100];
volatile byte pos;
volatile boolean process_it;
void setup (void)
Serial.begin (115200); // debugging
// turn on SPI in slave mode
SPCR |= bit (SPE);
// have to send on master in, *slave out*
pinMode(MISO, OUTPUT);
// get ready for an interrupt
pos = 0; // buffer empty
process_it = false;
// now turn on interrupts
SPI.attachInterrupt();
} // end of setup
// SPI interrupt routine
ISR (SPI_STC_vect)
byte c = SPDR; // grab byte from SPI Data Register
// add to buffer if room
if (pos < (sizeof (buf) - 1))
buf [pos++] = c;
// example: newline means time to process buffer
if (c == '\n')
process_it = true;
} // end of interrupt routine SPI_STC_vect
// main loop - wait for flag set in interrupt routine
void loop (void)
if (process_it)
buf [pos] = 0;
Serial.println (buf);
pos = 0;
process_it = false;
} // end of flag set
} // end of loop
From the sound of it i am not alone where i am struggling with the pointers aspect. I have been going through pointer tutorials but i still can not make sense of it. At the moment my understanding is that the declaration of the pointer and the dereferencing is done in one statement i.e.
so the const char *p on the left hand side of the '=' sign is setting aside the amount of memory of size char at a location. then the actual string is assigned to that memory location. Then i get stuck with
c = *p; p++
i know that 'p++' is moving the memory location that the pointer is pointing at by 1, nut i don't understand the 'c = *p' part as when reading it said that this is illegal so i'm obviously missing something.
As i intend to send integers i have broken down three data values of 10,000, 20,000 and 30,000 into high bytes and low bytes as recommended and put them in an array. do i need to use pointers or can i just use a for loop? My non working attempt to send 3 integers broken down is below but isn't working.
MASTER
// February 2011
#include <SPI.h>
void setup (void)
SPI.begin ();
} // end of setup
void loop (void)
// break down data into high and low bytes
int data_x = 10000;
byte high_byte_x = highByte(data_x);
byte low_byte_x = lowByte(data_x);
int data_y = 20000;
byte high_byte_y = highByte(data_y);
byte low_byte_y = lowByte(data_y);
int data_z = 30000;
byte high_byte_z = highByte(data_z);
byte low_byte_z = lowByte(data_z);
byte Stop = 0;
//declare c[] array
byte c[7] = {high_byte_x, low_byte_x, high_byte_y, low_byte_y, high_byte_z, low_byte_z, Stop};
// send test bytes one by one
for (int i = 0; i < 7; i++){
SPI.transfer(c[i]);
//delay (1000); // 1 seconds delay
} // end of loop
SLAVE
// February 2011
#include <SPI.h>
char buf [100];
volatile byte pos;
void setup (void)
SPCR |= bit (SPE);
process_it = false;
} // end of setup
ISR (SPI_STC_vect)
byte high_byte_x;
byte low_byte_x;
byte high_byte_y;
byte low_byte_y;
byte high_byte_z;
byte low_byte_z;
byte Stop;
for(int i = 0; i < 7; i++){
c[i] = SPDR; // grab byte from SPI Data Register
if (pos < (sizeof (buf) - 1)){
buf [pos++] = c[i];
if (c[i] == 0)
process_it = true;
void loop (void)
if (process_it)
buf [pos] = 0;
for(int j = 0; j < 100; j++){
Serial.println (buf[j], BIN);
pos = 0;
process_it = false;
} // end of loop
Thanks
Ross
