Hi guys,
I'm trying to send a string between two micro-controllers via SPI, but I don't have enough programming knowledge.
So far I can send and receive constant value.
My connection:
Master Code (Arduino Leonardo):
#include <SPI.h>
void setup (void) {
pinMode(8,OUTPUT);
Serial.begin(9600); //set baud rate to 115200 for usart
digitalWrite(8, HIGH); // disable Slave Select
SPI.begin ();
SPI.setClockDivider(SPI_CLOCK_DIV64);//divide the clock by 8
void loop (void) {
char c;
digitalWrite(8, LOW); // enable Slave Select
// send test string
for (const char * p = "Hello, world!\r" ; c = *p; p++)
SPI.transfer (c);
Serial.print(c);
delay(2000);
Slave Code (Arduino UNO):
#include <SPI.h>
char buff [50];
volatile byte indx;
volatile boolean process;
void setup (void) {
Serial.begin (9600);
pinMode(12, OUTPUT); // have to send on master in so it set as output
SPCR |= _BV(SPE); // turn on SPI in slave mode
indx = 0; // buffer empty
process = false;
SPI.attachInterrupt(); // turn on interrupt
ISR (SPI_STC_vect) // SPI interrupt routine
byte c= SPDR; // read byte from SPI Data Register
if (indx < sizeof buff) {
buff [indx++] = c; // save data in the next index in the array buff
if (c == '\r') //check for the end of the word
process = true;
void loop (void) {
if (process) {
process = false; //reset the process
Serial.println (buff); //print the array on serial monitor
indx= 0; //reset button to zero
delay(2000);
Could you give me a tip how to send a string via SPI? I would like to measure a temperature (DS18B20) on Arduino Leonardo and screen it on LCD which is connected to Arduino UNO.
#include <SPI.h>
#include <LiquidCrystal.h>
#define pinRS 2
#define pinE 3
#define pinDB4 4
#define pinDB5 5
#define pinDB6 6
#define pinDB7 7
char buff [50];
volatile byte indx;
LiquidCrystal lcd(pinRS, pinE, pinDB4, pinDB5, pinDB6, pinDB7);
void setup (void)
process = false;
lcd.clear();
lcd.begin(20, 4);
lcd.setCursor(0,0);
lcd.print("Mateusz");
process = true;
void loop (void) {
if (process) {
delay(2000);
