Hi all,
I'm new to SPI and a bit in at the deep end here. I'm trying to talk to this chip (A89503) over SPI. It has a bunch of registers that are WRITE(such as the gates), but at the moment I'm trying to READ from any of the 3 diagnostics channels. (refer to P.28, Table 6 in datasheet linked).
https://www.allegromicro.com/-/media/files/datasheets/a89503-datasheet.ashx
At the moment I'm just trying to read from Diag0 listed there using the code below as a test.
It's a 16 bit register so am sending 2 bytes each time.
weird thing I can't figure out is that presumably the chip will wait to receive all 16bits before sending any data, but then I can only see how I could receive one byte back, just because of how the arduino library seems to work there. So what am I doing wrong / misunderstanding here please, or can I not use Arduino for this functionality?
Thanks,
John
// SPI config test for SAMD21
#include <SPI.h>
#include "wiring_private.h" // pinPeripheral() function
SPIClass mySPI (&sercom1, 12, 13, 11, SPI_PAD_0_SCK_1, SERCOM_RX_PAD_3);
//D3 for chip select pin
const int chipSelectPin = 3;
unsigned int result = 0; // result to return
// initalize the chip select pins:
pinMode(chipSelectPin, OUTPUT);
// do this first, for Reasons
mySPI.begin();
// Assign pins 11, 12, 13 to SERCOM functionality
pinPeripheral(11, PIO_SERCOM);
pinPeripheral(12, PIO_SERCOM);
pinPeripheral(13, PIO_SERCOM);
mySPI.beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0));
digitalWrite(chipSelectPin, LOW);
mySPI.transfer(0b11000000);
result = mySPI.transfer(0b00000001);
digitalWrite(chipSelectPin, HIGH);
mySPI.endTransaction();
Serial.println("chip select sent");
Serial.print("data sent: ");
Serial.println(0b11000000, BIN);
Serial.println(0b00000001, BIN);
Serial.print("data received: ");
Serial.println(result, BIN);
delay (1000);
