Hi all,
I've been working on this project for a few weeks now, and while I've made some progress, I've hit a wall. I am fairly new to arduino, so the answer here may be simple, but I'm just not seeing it.
I am attempting to combine an Arduino Uno, an Adafruit Ultimate GPS Logger, and a Ocean Controls Thermocouple Multiplexer. I have been able to get each shield working properly on its own with the arduino, but when I attempt t combine them, they do not function properly. The FAQ for the thermocouple multiplexer states this:
You can't use SPI and Bit-Banging at the same time. The Adafruit SD library supports Bit-Banging for SD card like this SD.begin(chipSelect, 11, 12, 13); so you will need to download Adafruit's SD library from here:
https://github.com/adafruit/SD/archive/master.zip
There are also a number of other threads on similar topics, both on this board and others. I've attempted the solutions posted there, but I haven't been able to get the thing to work.
Currently, the largest hurdle I have is that I am unable to reliably initialize the SD card when the thermocouple shield is installed. The thermocouple uses bit-banged SPI to communicate with the arduino, so initially my problem was that I was attempting to use SPI communications to the SD card, and bit-banged SPI to talk to the thermocouple shield, which I've since found out are incompatible with each other.
Due to information I found in one of the threads linked above, I switched to the SdFat library from the adafruit SD library in an effort to avoid SPI conflicts. I went into the SdFatConfig.h file and enabled the USE_SOFTWARE_SPI switch to accomplish the same result as what the FAQ suggested, but I think I am still having the same issue as the symptoms are the same.
As a troubleshooting measure, I wrote/borrowed/mangled a simple sketch to talk to the SD card, which looks like this:
#include <SdFat.h>
SdFat sd;
SdFile myFile; //data output file
//-----SD Variable Definitions-----
#define SDPINCS 10 //SD Chip Select
char i; //general use integer
String buf; //general use string
//-----Open serial communications-----
Serial.print("Initializing SD Card...\r\n");
if (!sd.begin(SDPINCS, SPI_HALF_SPEED)) sd.initErrorHalt();
Serial.println("SD initialization done.");
if (!myFile.open("test.txt",O_RDWR | O_CREAT | O_AT_END)) {
sd.errorHalt("opening test.txt for write failed");
myFile.println("Temp0,Temp1,Temp2,Temp3,Temp4,Temp5,Temp6,Temp7");
myFile.close();
if (millis()<10000){//Temporary limit for debugging
Serial.print("\n");
for (i=0;i<8;i++){
Serial.print(millis()); //used as an example to debug instead of temperatures, below.
Serial.print(","); //used as an example to debug instead of temperatures, below.
myFile.print(millis()); //used as an example to debug instead of temperatures, below.
myFile.print(","); //used as an example to debug instead of temperatures, below.
Serial.print("\n");
myFile.print("\n");
else{
myFile.close();
Serial.println("Data file closed.");
With the thermocouple shield absent, it works fine. With it installed, the data looks like this (multiple runs prompted by pressing the "reset" button):
Can't access SD card. Do not reformat.
No card, wrong chip select pin, or SPI problem?
SD errorCode: 0X1,0X0
SD errorCode: 0X8,0X1
SD errorCode: 0X4,0X4
SD errorCode: 0XF,0X7F
56,56,57,57,57,57,58,58,
1058,1058,1059,1059,1059,1060,1060,1061,
2062,2062,2063,2063,2063,2064,2064,2065,
3065,3065,3066,3066,3066,3067,3067,3068,
4069,4069,4070,4070,4070,4071,4071,4072,
5072,5072,5073,5073,5073,5074,5074,5075,
6076,6076,6077,6077,6078,6078,6078,6079,
7079,7079,7080,7080,7081,7081,7081,7083,
8083,8083,8084,8084,8085,8085,8085,8086,
9086,9086,9088,9088,9089,9089,9089,9090,
Data file closed.
The inconsistent error codes and intermittent functionality lead me to believe that there is some sort of conflict. I would really appreciate any insight that anyone might have on this problem. Thanks!
