Hello there. I have recently encountered a problem using SPI in TinkerCad. I have tried several projects, but none of them worked as expected. I need a short example of how to send information from Master to Slave with two Arduinos UNO. Is that possible? I used SPI.h header file, but it didn't work as expected. Should I use codes that seem to work with IDE right away, in reality? May it be a TinkerCad glitch?
Here is the link: Circuit design SPI_Glitch | Tinkercad
For informed help, please read and follow the instructions in the "How to get the best out of this forum" post. linked at the head of every forum category.
jremington, thank you very much for your reply. Finally, I tried it on Arduino IDE and everything works fine. Probably, it's something wrong with TinkerCad. I informed on this issue to their forum.
