Hi, an arduino is an arduino usb hostshield barcode reader attached to it.
i have an lcd i2c driver and a rc522 rfid reader.
It communicates over hostshield and rc522 spi over lcd i2c. All working alone but not working together
#include <SPI.h>
#include <MFRC522.h>
#include <HID.h>
#include <hid.h>
#include <hiduniversal.h>
#include <LiquidCrystal.h>
#include <avr/pgmspace.h>
#include <SPI.h> //SPI kütüphanemizi tanımlıyoruz.
#include <MFRC522.h> //MFRC522 kütüphanemizi tanımlıyoruz.
#include <Usb.h>
#include <usbhub.h>
#include <hidboot.h>
int led = A0;
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 7 // Configurable, see typical pin layout above
#define SS_USB 10
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
MFRC522::MIFARE_Key key;
float toplam = 0;
int i = 0;
float pkalem = 4.70;
float ple = 0.65;
char harfler[13] = {'0', '0', '0', '0', '0', '0', '0', '0', '0', '0', '0', '0', '0'};
char kalem[13] = {'9', '7', '9', '9', '7', '5', '3', '2', '9', '3', '6', '8', '5'};
char le[13] = {'8', '6', '9', '1', '0', '1', '4', '0', '0', '0', '0', '1', '2'};
LiquidCrystal_I2C lcd(0x27,16,2);
USB Usb;
USBHub Hub(&Usb);
HIDUniversal Hid(&Usb);
class KbdRptParser : public KeyboardReportParser
void PrintKey(uint8_t mod, uint8_t key);
protected:
virtual void OnKeyDown (uint8_t mod, uint8_t key);
virtual void OnKeyPressed(uint8_t key);
void KbdRptParser::OnKeyDown(uint8_t mod, uint8_t key)
uint8_t c = OemToAscii(mod, key);
if (c)
OnKeyPressed(c);
void KbdRptParser::OnKeyPressed(uint8_t key)
static uint32_t next_time = 0;
if ( millis() > next_time ) {
i = 0;
delay( 5 );
next_time = millis() + 200;
//Serial.print( (char)key );
harfler[i] = (char)key;
//Serial.print("i = "); Serial.println(i);
//Serial.print("bs harfler = "); Serial.print(harfler[0]); Serial.print("."); Serial.print(harfler[1]); Serial.print("."); Serial.print(harfler[2]); Serial.print("."); Serial.println(harfler[3]);
i++;
if (harfler[7] == kalem[7])
{ if (harfler[8] == kalem[8])
{ if (harfler[9] == kalem[9])
{ if (harfler[10] == kalem[10])
{ if (harfler[11] == kalem[11])
{ if (harfler[12] == kalem[12])
if (i == 13)
toplam = pkalem + toplam;
String kalems = String(pkalem);
digitalWrite (led, 1);
lcd.setCursor( 0, 0);
lcd.print("KALEM. 4.70 TL");
lcd.setCursor( 0, 1);
lcd.print("TOPLAM ");
lcd.setCursor( 7, 1);
lcd.print(toplam);
lcd.setCursor( 14, 1);
lcd.print("TL");
if (harfler[7] == le[7])
{ if (harfler[8] == le[8])
{ if (harfler[9] == le[9])
{ if (harfler[10] == le[10])
{ if (harfler[11] == le[11])
{ if (harfler[12] == le[12])
if (i == 13)
toplam = ple + toplam;
String ples = String(ple);
char charBuf[5];
ples.toCharArray(charBuf, 5);
Serial.write(charBuf,5);
Serial.println(charBuf);
lcd.print("LE'PORT. 0.65 TL");
lcd.print(toplam);
lcd.print("TL");
if (i == 13)
Serial.print("yabanci");
lcd.print(" TANIMSIZ URUN ");
lcd.print(harfler[0]);
lcd.print(harfler[1]);
lcd.print(harfler[2]);
lcd.print(harfler[3]);
lcd.print(harfler[4]);
lcd.print(harfler[5]);
lcd.print(harfler[6]);
lcd.print(harfler[7]);
lcd.print(harfler[8]);
lcd.print(harfler[9]);
lcd.print(harfler[10]);
lcd.print(harfler[11]);
lcd.print(harfler[12]);
lcd.print(" ");
Serial.print(harfler[3]);
Serial.print(harfler[4]);
Serial.print(harfler[5]);
Serial.print(harfler[6]);
Serial.print(harfler[7]);
Serial.print(harfler[8]);
Serial.print(harfler[9]);
Serial.print(harfler[10]);
Serial.print(harfler[11]);
Serial.println(harfler[12]);
KbdRptParser Prs;
int sil_pini = A1;
int sil;
* Initialize.
delay(200);
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
if (Usb.Init() == -1) {
//Serial.println("OSC Başlatılamadı.");
// delay( 200 );
Hid.SetReportParser(0, (HIDReportParser*)&Prs);
lcd.begin(16, 2);
lcd.clear();
lcd.noAutoscroll();
lcd.print("ALINAN URUNLERIN");
lcd.print("TOPLAMI 00.00 TL");
delay(200);
// Prepare the key (used both as key A and as key B)
// using FFFFFFFFFFFFh which is the default at chip delivery from the factory
for (byte i = 0; i < 6; i++) {
key.keyByte[i] = 0xFF;
Serial.println(F("Scan a MIFARE Classic PICC to demonstrate read and write."));
Serial.print(F("Using key (for A and B):"));
dump_byte_array(key.keyByte, MFRC522::MF_KEY_SIZE);
Serial.println(F("BEWARE: Data will be written to the PICC, in sector #1"));
* Main loop.
// Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
// Show some details of the PICC (that is: the tag/card)
Serial.print(F("Card UID:"));
dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
Serial.print(F("PICC type: "));
MFRC522::PICC_Type piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
Serial.println(mfrc522.PICC_GetTypeName(piccType));
// Check for compatibility
if ( piccType != MFRC522::PICC_TYPE_MIFARE_MINI
&& piccType != MFRC522::PICC_TYPE_MIFARE_1K
&& piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
Serial.println(F("This sample only works with MIFARE Classic cards."));
return;
// In this sample we use the second sector,
// that is: sector #1, covering block #4 up to and including block #7
byte sector = 1;
byte blockAddr = 4;
byte dataBlock[] = {
0x01, 0x02, 0x03, 0x04, // 1, 2, 3, 4,
0x05, 0x06, 0x07, 0x08, // 5, 6, 7, 8,
0x09, 0x0a, 0xff, 0x0b, // 9, 10, 255, 11,
0x0c, 0x0d, 0x0e, 0x0f // 12, 13, 14, 15
byte trailerBlock = 7;
MFRC522::StatusCode status;
byte buffer[18];
byte size = sizeof(buffer);
// Authenticate using key A
Serial.println(F("Authenticating using key A..."));
status = (MFRC522::StatusCode) mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, trailerBlock, &key, &(mfrc522.uid));
if (status != MFRC522::STATUS_OK) {
Serial.print(F("PCD_Authenticate() failed: "));
Serial.println(mfrc522.GetStatusCodeName(status));
return;
// Show the whole sector as it currently is
Serial.println(F("Current data in sector:"));
mfrc522.PICC_DumpMifareClassicSectorToSerial(&(mfrc522.uid), &key, sector);
// Read data from the block
Serial.print(F("Reading data from block ")); Serial.print(blockAddr);
Serial.println(F(" ..."));
status = (MFRC522::StatusCode) mfrc522.MIFARE_Read(blockAddr, buffer, &size);
Serial.print(F("MIFARE_Read() failed: "));
Serial.print(F("Data in block ")); Serial.print(blockAddr); Serial.println(F(":"));
dump_byte_array(buffer, 16); Serial.println();
// Authenticate using key B
Serial.println(F("Authenticating again using key B..."));
status = (MFRC522::StatusCode) mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_B, trailerBlock, &key, &(mfrc522.uid));
return;
// Write data to the block
Serial.print(F("Writing data into block ")); Serial.print(blockAddr);
dump_byte_array(dataBlock, 16); Serial.println();
status = (MFRC522::StatusCode) mfrc522.MIFARE_Write(blockAddr, dataBlock, 16);
Serial.print(F("MIFARE_Write() failed: "));
// Read data from the block (again, should now be what we have written)
// Check that data in block is what we have written
// by counting the number of bytes that are equal
Serial.println(F("Checking result..."));
byte count = 0;
for (byte i = 0; i < 16; i++) {
// Compare buffer (= what we've read) with dataBlock (= what we've written)
if (buffer[i] == dataBlock[i])
count++;
Serial.print(F("Number of bytes that match = ")); Serial.println(count);
if (count == 16) {
Serial.println(F("Success :-)"));
Serial.println(F("Failure, no match :-("));
Serial.println(F(" perhaps the write didn't work properly..."));
// Dump the sector data
// Halt PICC
mfrc522.PICC_HaltA();
// Stop encryption on PCD
mfrc522.PCD_StopCrypto1();
* Helper routine to dump a byte array as hex values to Serial.
void dump_byte_array(byte *buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
Serial.print(buffer[i] < 0x10 ? " 0" : " ");
Serial.print(buffer[i], HEX);
sil = analogRead (sil_pini);
if (sil > 500)
toplam = 0;
lcd.print(toplam);
lcd.print("TL");
digitalWrite (led, 0);
Usb.Task();
