Hi all,
I am pretty new to implementing SPI communication but I seem to have the code working on an Arduino UNO - yay! However, my project requires me to use a Raspberry Pi PICO 2350 as the microcontroller. I have downloaded the appropriate board manager from Earlephilhower and selected Raspberry Pi Pico for the board. I verified that I am able to see the serial monitor and upload code to the Pico with a simple print statement - yay! Next, the problem comes when trying to reconfigure the hardware to the appropriate pins on the PICO so that they match defaults in the built-in SPI library. I can't seem to get any data from my code when connected to the default SPI pins of the RP Pico (Pins 21, 22, 24 & 25). Is there a way to explicitly define these pins in the code?
I used this code to try to get the defaults:
CODE:
Serial.print("Default SPI0 MOSI: ");
Serial.println(PIN_SPI0_MOSI);
Serial.print("Default SPI0 MISO: ");
Serial.println(PIN_SPI0_MISO);
Serial.print("Default SPI0 SCK: ");
Serial.println(PIN_SPI0_SCK);
OUTPUT:
Default SPI0 MOSI: 23
Default SPI0 MISO: 20
Default SPI0 SCK: 22
This doesn't make sense to me since pin 23 on the RP Pico is ground. Any guidance would be super helpful. Thanks! ![]()
TLDR: What are the default pin numbers on RP Pico 2350 to use with SPI library?
