I am getting a stream of data at pin 11 (MISO) but only 100mv p-p. This is with no load. The logic starts at 5V, then drops to near zero, then the small level data stream. Data from pin 11 works fine with 74HC595 sketch!
Also, the SS pin does go low when requested but the SS line from the FPGA is pulled up to 3.3V through a 100K resistor and will not get pulled down lower than 3.3V via pin 11.
Any ideas?
- howdyrichard
