SPI Speed & Flash string
Hi
Max speed of the SPI is 12Mhz.
For obtain 24Mhz I change IDE souces code at line 45
Exist a way for obtain same speed without changing the IDE file?
Second question.
About Print, ex TFT.print() file.print() serial.print()
https://github.com/arduino/ArduinoCore-samd/blob/master/cores/arduino/Print.cpp
There are 2 function ? One for print String from ram and one from flash ?
This ?
size_t Print::print(const __FlashStringHelper *ifsh)
size_t Print::print(const String &s)
is right if i say:
print("hello")
string is copied from flash to ram, ad startup, then print from ram.
print(F"hello")
string is printed direclty from flash
Naturally, all this is intended with ARM SAMD
No, booth of this are const = Flash.
Explain me.
This post read 880 time and nobody gives me advice?
#define F(string_literal) (reinterpret_cast<const __FlashStringHelper *>(PSTR(string_literal)))
I found this but I do not understand.
No, booth of this are const = Flash. Explain me.
They would be different on an AVR, so both versions exist for the sake of compatibility.
As for SPI, the library says:
// New programs should use SPI.beginTransaction to set the SPI clock
See SPI - Arduino Reference
I don't think that the original SPI code had beginTransaction(), so many of the examples don't use it.
Max speeed, using original library is 12mhz
