SPI to USB interface
Hi Everyone,
Can anyone tell me if it is possible to use one of the mini Arduino boards to convert from an SPI interface to a USB interface. I would like to have a small hopefully the size of a chewing gum packet box with a USB connection and a screen attached then the ability to push an image/text to the screen via USB.
Will this work ? Has anyone got any ideas or can you tell me what components would be best
Thanks for the help
Jonathan
The Fundamental Logic iDuino has onboard USB and sells for about $18
Imgur
Maybe you can use that
There are other boards like it as well
:slight_smile:
THanks for the information, that looks great, does it have the ability to connect SPI to the board or would i need to build a mini shield or something like that ?
Also how easy would it be to swap the USB connection to Mini USB ?
Thanks for your help
The iDuino has onboard USB which can be used to communicate with it and power it at the same time so I don't think you would need anything else
Do you need another USB connection? If you do what do you plan to use it for?
You could use a mini-USB to USB-B adapter
The iDuino normally comes with the USB-B connector and FTDI chip pre-soldered because those are quite difficult to solder by hand
:slight_smile:
Hi Thanks for the reply, i saw that it comes with the USB A already soldered onto the board but may try to solder a mini usb connection on to it.
So with the board i have USB connection and i have everthing on the board to be able to connect an LCD screen via SPI.
Have i got that correct :-[
Thanks for the advice and help
I think you can use a K107 LCD backpack from Wulfden or a similar board from Modern Device
http://wulfden.org/TheShoppe/k107/k107-51.jpg
http://moderndevice.com/Images/LCDpop300.jpg
The K107 only requires 1 signal pin from the Arduino to operate plus power
I believe SPI requires 4 pins and is a lot more complicated
:slight_smile:
