I am doing an SPI transfer with an arduino due to an AD9833 chip. For some reason i can not figure out the chip select (CS) pin is not staying low for the duration of the transfer. Code and waveform shown below.
I put in only the relevant code here
#include <SPI.h>
#define slaveSelectPinAD9833 52
SPI.begin(slaveSelectPinAD9833);
SPI.setDataMode(slaveSelectPinAD9833, SPI_MODE2);
Serial.println("Testing SPI");
delay(4);
SPI.transfer(slaveSelectPinAD9833, 0x21, SPI_CONTINUE);
SPI.transfer(slaveSelectPinAD9833, 0x00, SPI_CONTINUE);
SPI.transfer(slaveSelectPinAD9833, 0x50, SPI_CONTINUE);
SPI.transfer(slaveSelectPinAD9833, 0xC7, SPI_CONTINUE);
SPI.transfer(slaveSelectPinAD9833, 0x40, SPI_CONTINUE);
SPI.transfer(slaveSelectPinAD9833, 0xC0, SPI_CONTINUE);
SPI.transfer(slaveSelectPinAD9833, 0x20, SPI_CONTINUE);
SPI.transfer(slaveSelectPinAD9833, 0x00);
delay(200);
As can be seen the enable pin on 52 does not always stay low for the duration of the transfer. Some times the transfer does work but most of the time it does not. I even tried to set a seperate pin (22) as just an output pin and set it low before transfer, but even hooking up that pin showed a similar result. It would periodically go high in the middle of the transfer even though it was set as output low. The enable pin does this when it is both connected and not connected to the AD9833.
Anyone else have this issue or know why the enable pin will periodically go high, or why SPI transfer can affect other output pins?
