SPI Transfer freeze code execution
Hello everyone,
I have 2 Arduino Uno boards wired for SPI communication. On the first board (Master) I read some data from a potentiometer (i have to simulate a pressure sensor) and I want to send the data to the second board (slave) to display the results on an LCD. The thing is that every time I run the program, the loop freeze at the first execution, on the SPI.transfer(0x01) exactly. I tried a lot of version of different codes but without success.
Here is the code for Master:
#include <SPI.h>
int sensorValue = 0;
float presure = 0;
int Vs = 0;
void setup(){
  pinMode(A0, INPUT);
  pinMode(10, OUTPUT);
  digitalWrite(10, HIGH);
  SPI.begin();
  Serial.begin(57600);
  // read the value from the sensor
  sensorValue = analogRead(A0);
  Vs = 1023;
  presure = (sensorValue/Vs + 0.095) / 0.009;
  Serial.print(sensorValue);
  SendDataToSlave(presure);
void SendDataToSlave(float presure)
  digitalWrite(10, LOW);
  delay(1);
  SPI.transfer(0x00); //just a mock
And this one is for the slave:
#include <SPI.h>
bool data_received = false;
float presure_received = 1996;
  SPCR |= _BV(SPE);
  SPI.attachInterrupt();
ISR(SPI_STC_vect){
    uint8_t presure_test = SPDR; // Get the presure sent from the data register of SPI
    data_received = true;
    //Sample code.
    //This section is for sending data to LCD.
    //Mock for testing only. Please delete this in the last version.
    if(data_received == true)
        Serial.print(presure_received);
I uploaded the circuit diagram in the attach
Thank you, everyone!
Image from Original Post so we don't have to download it. See this Simple Image Guide
...R
That line doesn't exist in the posted code. I can only find
SPI.transfer(0x00);
How do you know that it freezes in the SPI code? Did you check with a logic analyzer? Does D10 stay LOW?
