My Arduino is sending data from two ADC channels (CH1 and CH2), unfortunately the software i use in Windows doesnt work with multiple channels, so i´m only using one channel
Using some script i manipulate the data, the script will recognize which channel, remove the "CH1:" tag and send it only the values to a virtual serial port:
-CH1: 100 - Goes to virtual Port X as "100"
-CH2: 210 - Goes to virtual Port Y as "210"
-CH1: 123 - Goes to virtual Port X as "123"
With this method i will have two Virtual Serial Ports - X for CH1 and Y for CH2 - and i can use two softwares to monitor data from CH1 and CH2.
Anyone knows a software/freeware which is capable of doing this?
What software are you using?
The correct way to do this is to have a program on your PC reading the incoming data on the serial port and parse to determine the channel in question, then do whatever it is you want with the data. Display it, save it etc.
I wish to test in different softwares..but its for log the data from the ADC. But the softwares only access data serial port..so even i can managed to do a script to parse the data i need to send to a "virtual serial port" to the software accept the data.
Another way i thought on doing this, is to have two arduinos:
-The Arduino 1 with ADC will Serial.Print the data from CH1 and send the data from CH2 to Arduino 2, the Arduino 2 receive it and Serial.Print
Will this work?
I prefere using a software/script, but using two arduinos its better than only getting one channel per time.
Will this work?
Will this work?
With 2 Arduino's it will definitely work.
Thanks for the answer.. indeed that application splits correctly the data to two or more virtual serial ports, but i cant manipulate the data using the splitter software and in the software to plot the data..its a closed software and it can only read from a Serial Port.
I cant find any software/freeware for this issue and since my programming skill are limited, i dont know how to wrote a program to do this.
My best solution is to have two Arduinos, but later i will like to use 3 ADC channels, so 3 arduinos its a bit extreme just to parse the data..
Aother option might be an application that connects to the serial port and splits the data and offers it as three network sockets?
(never done this, not trivial, but doable and it would be a great tool if it works....)
Have you checked gobetwino.exe ? does offer some nice features too, might need a redesign on the Arduino side a bit ...
Maybe gobetwino.exe will do the trick..but working at 65SPS each channel, whats the reliability of the data? Not only for gobetwino.exe, i need a reliable method to not loose packets.
But i did once used a opensource project (com0com) which splits the serial port to different virtual serial ports..according to the readme:
The HUB for communications (hub4com) is a Windows application and is a part of
the com0com project.
It allows to receive data and signals from one port, modify and send it to a
number of ports and vice versa.
So this should be the solution, right?
The problem is looking to the source code or to the commands on hub4com dont know where to start.. any help i appreciate.
The compiler is right. This code is rubbish. The documentation provided is not provided because people like to sit around writing documentation. It is there because people need to read it. That includes you.
I can't figure out what you think you are doing in the Serial.print() statement, so I have no idea how to help you. Most likely, you need to put those values in an array, and print the array.
As for the new line, that's what Serial.println() does.
I was trying to send the data (0102030\n) in binary..to hub4com remove the "0" and create a new line..ending like:
123
123
123
123
Like i said before, i´m parsing the data ok to the virtual serial ports, but the problem is that hub4com does not create a new line..but i think that i need to send the data in binary rather than ASCII for Hub4Com...so to send data in binary i need to work in serial.write?
binary, ascii, etc..its really confusing for me, i agree that i have to learn a lot more..
