I'm a bit new to programming, and just started on my first big project.
The Arduino receives a String from my computer, and saves the whole string.
I want to split this string in to three integers. How can I do that?
// Buffer to store incoming commands from serial port
String inData;
Serial.println("Waiting for LabView to send a signal...\n");
while (Serial.available() > 0)
char recieved = Serial.read();
inData += recieved;
// Process message when new line character is recieved
if (recieved == ';')
Serial.print("Arduino Received: ");
Serial.println(inData);
inData = ""; // Clear recieved buffer
String from PC looks like this: 12,14,14;
The inData looks like this: 12,14,14
I want to move the three numbers to three different variables/integers. And everytime the Arduino recives a new string, the old values in the integers should med written over.
char input[] = "12,14,15";
char separator[] = ",";
char *token;
/* get the first token */
token = strtok(input, separator);
// Find any more?
while(token != NULL)
Serial.println(token );
token = strtok(NULL, separator);
Serial.println(input); // Proof that original string is chopped up
On the first call to strtok(), you pass in the input string and a second string that holds the character(s) that delimit the fields in the input stream. In this example, we are only using the comma, but you can have as many as you want. If strtok() finds a token from the separator list, it returns a pointer to the first substring if finds. Internally, it also maintains a pointer to the token, so in this example, token points to "12" and the internal pointer points to the comma between 12 and 14. However, the function overwrites the comma with a null ('\0') character so the substring ("12") can be treated as a string (note lowercase 's').
On the next call to strtok(), token is advanced to the next character in the input stream (the '1' in 14) and the internal pointer advances to the next comma, where it overwrites it with a null. The call then returns the pointer to "14". This process continues until all separators have been found. Note that strtok() destroyes the original input string in the process.
If your data string id delimited with commas, then you might use code similar to the below. You can also change the character value into a number if needed.
int n = readString.toInt();
//zoomkat 11-12-13 String capture and parsing
//from serial port input (via serial monitor)
//and print result out serial port
//copy test strings and use ctrl/v to paste in
//serial monitor if desired
// * is used as the data string delimiter
// , is used to delimit individual data
String readString; //main captured String
String angle; //data String
String fuel;
String speed1;
String altidude;
int ind1; // , locations
int ind2;
int ind3;
int ind4;
Serial.println("serial delimit test 11-12-13"); // so I can keep track of what is loaded
//expect a string like 90,low,15.6,125*
//or 130,hi,7.2,389*
if (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
if (c == '*') {
//do stuff
Serial.print("captured String is : ");
Serial.println(readString); //prints string to serial port out
ind1 = readString.indexOf(','); //finds location of first ,
angle = readString.substring(0, ind1); //captures first data String
ind2 = readString.indexOf(',', ind1+1 ); //finds location of second ,
fuel = readString.substring(ind1+1, ind2+1); //captures second data String
ind3 = readString.indexOf(',', ind2+1 );
speed1 = readString.substring(ind2+1, ind3+1);
ind4 = readString.indexOf(',', ind3+1 );
altidude = readString.substring(ind3+1); //captures remain part of data after last ,
Serial.print("angle = ");
Serial.println(angle);
Serial.print("fuel = ");
Serial.println(fuel);
Serial.print("speed = ");
Serial.println(speed1);
Serial.print("altidude = ");
Serial.println(altidude);
readString=""; //clears variable for new input
angle="";
fuel="";
speed1="";
altidude="";
else {
readString += c; //makes the string readString
