splitting decimal number to 2 pieces
Hi!
I tried to figure this out last 2 weeks without manage to solve it(googleling, reading this forum for hours, testing different types of libraries etc). So I registered in here.
So, I try to make 3 digit 7-segment display(via three 74hc595 multiplexer) which displays decimal number for example 36.7(temperature which is always between 10.0 to 40.9 C) . To showing integer numbers is not a problem(working fine), but I can't manage to find out how to divide decimal number to two pieces (because i assume that to light decimal point on I have to have after decimal point numbers separated from number before decimal point).
Just because English isn't my native I will explain it other way too:
Problem: 37.7 (Temp which is always between 10.0 to 40.9 C )
need to get this format:
int a = 37
int b=7
to get it to the 7-segment display which will show 37.7.
-Toni
ps. Programming is new to me.
Demo code. You tell us
A. Why this works (work it out with paper and pen before answering.
B. How would you deal with 2 digits after the decimal point?
float temp = 37.9;
int a;
int b;
  a = temp; // gets the first part as going from (casting)
  //float to int drops the bit after the decimal point
  Serial.print("before the point ");
  Serial.println(a);
  // get the second part
  b= temp*10-a*10;
  Serial.print("after the point ");
  Serial.print(b);
Mark
int a = (int)temp;
int b = temp - a;
No division necessary.
you can also use dtostrf() to create a character string out of it, and simply look for the '.' so you can pick it apart and send it, since you need a character anyway.
Thanks to all of you!
Answer was really really simple. But sometimes you just can't see it :slight_smile:
I solved this out this way with your help:
 const int  latchPin = 42;
 const int  clockPin     = 41;
 const int  dataPin    = 44;
float temp=0.0;
int a=0;
int b=0;
int c;
int d;
byte g_digits[10];
byte g_digitsd[10];
float temp2=1.1;
   pinMode (latchPin, OUTPUT);
   pinMode (clockPin, OUTPUT);
   pinMode (dataPin, OUTPUT);
   Serial.begin (115200);
 g_digits [0] = 1 + 2 + 4 + 8 + 16 + 32 + 00;
g_digits [1] = 0 + 2 + 4 + 0 + 00 + 00 + 00;
g_digits [2] = 1 + 2 + 0 + 8 + 16 + 00 + 64;
g_digits [3] = 1 + 2 + 4 + 8 + 00 + 00 + 64;
g_digits [4] = 0 + 2 + 4 + 0 + 00 + 32 + 64;
g_digits [5] = 1 + 0 + 4 + 8 + 00 + 32 + 64;
g_digits [6] = 1 + 0 + 4 + 8 + 16 + 32 + 64;
g_digits [7] = 1 + 2 + 4 + 0 + 00 + 00 + 00;
g_digits [8] = 1 + 2 + 4 + 8 + 16 + 32 + 64;
g_digits [9] = 1 + 2 + 4 + 8 + 00 + 32 + 64;
g_digitsd [0] = 1 + 2 + 4 + 8 + 16 + 32 + 00 +128;
g_digitsd [1] = 0 + 2 + 4 + 0 + 00 + 00 + 00 +128;
g_digitsd [2] = 1 + 2 + 0 + 8 + 16 + 00 + 64 +128;
g_digitsd [3] = 1 + 2 + 4 + 8 + 00 + 00 + 64 +128;
g_digitsd [4] = 0 + 2 + 4 + 0 + 00 + 32 + 64 +128;
g_digitsd [5] = 1 + 0 + 4 + 8 + 00 + 32 + 64 +128;
g_digitsd [6] = 1 + 0 + 4 + 8 + 16 + 32 + 64 +128;
g_digitsd [7] = 1 + 2 + 4 + 0 + 00 + 00 + 00 +128;
g_digitsd [8] = 1 + 2 + 4 + 8 + 16 + 32 + 64 +128;
g_digitsd [9] = 1 + 2 + 4 + 8 + 00 + 32 + 64 +128;
    temp=analogRead(A1);
  temp2=(temp/1024)*50;
 a= (int)temp2;
 b= temp2*10 - a*10;
 c=a/10;
 d=a-c*10;
Serial.println(a);
Serial.println(c);
Serial.println(d);
Serial.println(b);
Serial.println(temp2);
Serial.println("_____");
    digitalWrite(latchPin, 0);
    shiftOut(dataPin, clockPin, MSBFIRST, g_digits[c]);
    shiftOut(dataPin, clockPin, MSBFIRST, g_digits[d]);
    shiftOut(dataPin, clockPin, MSBFIRST, g_digitsd[b]);
    digitalWrite(latchPin, 1);
    delay(300);
I just replace thermometer with variable resistor to be able to change voltage quickly. I think that there is "cleaner way to do this but it seems works so it's ok to me.
-Toni
Aw man... good catch. My code example tried to save the remainder to an int. You would need a float for that to work (or, as you did, multiply the result by 10 for a single digit of precision.)
Sorry about that. :slight_smile: Glad you figured it out despite my goof-up.
You don't need floats at all.
If you declare temp2 as an int, you can use:
// the math here is that 500/1024 equals 125/256
temp2=(temp*125)/256; // temp2 is now in tenths of a degree
only that will overflow so instead use:
// the math here is:
// 500/1024 = 125/256 = 128/256 - 3/256 = 1/2 - 3/256
temp2=(temp/2)-((3*temp)/256); // temp2 is now in tenths of a degree
Since you have the temperature in tenths of a degree, all you need to do is insert a decimal point.
Did you know about the binary constant notation?
g_digitsd [4] =  0b11100110;
Just note that the biggest bit comes first (128 +64+32+4+2) so the bits are reversed compared to your sum.
